Guest Posted October 9, 2013 Share Posted October 9, 2013 Hi.would anyone be able to help me as i cannot get my head around it. the relay seems to be working just when i switch from right to left then it causes it to sparkle inside. the turn signal stays on lighted but if i turn to right again it is flashes all good. thanks rob Quote Link to comment Share on other sites More sharing options...
Tango Posted October 9, 2013 Share Posted October 9, 2013 Welcome to TMBF Rob........ Pop over to the Newbies section and introduce yourself to the rest of the gang when you get time...... Sorry mate but I'm struggling to understand what is happening here...... Where does the sparking come from.....is it the flasher relay or the indicator switch on the handlebars?...... Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted October 9, 2013 Share Posted October 9, 2013 if the relay is sparking replace it as it is either sticking on the left hand side of it or direct shorting Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted October 10, 2013 Share Posted October 10, 2013 Hi, probably worn contacts in the handlebar switch from what l can gather. The flasher unit is common to both side of the bike so if it is working on one side of the bike and not the other, it will be either the switch, the wiring or one of the lamps that's at fault. Quote Link to comment Share on other sites More sharing options...
