Guest Posted October 14, 2013 Share Posted October 14, 2013 Hi all does the runner quad lights have hi beamAs iv fitted them and the bulbs just look the same brightness I have low beam then switch to hi beam and it looks the same as low beamThe side lights are fineAnd i have to swich my mian beam and low beam switch to the middle for the hi beam light to go out and for light on the dash what shows the hi beam is on is that right..Its a Gilera runner 180....Any one knowHeres some pics i found on the net...http://i1060.photobucket.com/albums/t445/ben7649/Screenshots_2013-10-14-20-00-20_zps382a7c4b.pnghttp://i1060.photobucket.com/albums/t445/ben7649/Screenshots_2013-10-14-20-00-31_zps890cfd7d.png Quote Link to comment Share on other sites More sharing options...
Joeman Posted October 14, 2013 Share Posted October 14, 2013 If its the 180 two stroke and its in good condition, put it back to standard, they are an appreciating classic going up in value (Mine is in storage ) Quote Link to comment Share on other sites More sharing options...
Guest Posted October 14, 2013 Share Posted October 14, 2013 Hi mate to late iv had it for years its kitted to max same as the engine built it years ago but couldn't get hold of these lights then didnt look hard enough knowing my luck so got it back out and fitted some but got this problem... I built it from a frame and logbook etc. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 18, 2013 Share Posted October 18, 2013 hi, I had the same lights as this on my runner and could never get them to work properly,after many hours of trying I contacted an auto electrician,he had problems but managed to get them working not sure how but it was worth the £30 to save my insanity,all the best. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted October 18, 2013 Share Posted October 18, 2013 looking at the rear pic each bulb only has one filament in it so are you sure that one bulb isnt higher wattage than the other so you will have one on for low beam and turning high beam on will turn the other one on that has higher wattage Quote Link to comment Share on other sites More sharing options...
