dfrbrowne Posted October 24, 2013 Share Posted October 24, 2013 Just been out on my 656 Bandit for a run up the motorway, not used it for a couple of weeks.It took a minute to start and it is struggling to keep up the revs, I noticed at lo-res and slow speeds it was a bit jumpy and spluttery, it was fine on the motorway once above the 5,000/6,000 revs mark.Is it just in need of a service? Quote Link to comment Share on other sites More sharing options...
klingelton Posted October 24, 2013 Share Posted October 24, 2013 carbs or fuel injectors?Could be anyone of many things. first thing to check is the fuelling though. Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted October 24, 2013 Share Posted October 24, 2013 Sounds like blocked pilot jets to me. Quote Link to comment Share on other sites More sharing options...
banditjohn Posted October 24, 2013 Share Posted October 24, 2013 Stick a load of redex in the tank, get it into the carbs or injectors and then leave it to soak in as long as you can and hopefully give it a run it'll clear it. Quote Link to comment Share on other sites More sharing options...
Fozzie Posted October 25, 2013 Share Posted October 25, 2013 650 is fuel injected I believe!Run some STP injector cleaner through it, give it double the dose recommended just to really burn it through.My source being I've had the same problem and that cured it Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted October 25, 2013 Share Posted October 25, 2013 Damp electric's ? Quote Link to comment Share on other sites More sharing options...
