mytrenis Posted November 2, 2013 Share Posted November 2, 2013 Morning allSo got a problem with my er6n. Tried to start it last morning but it wont start. First thing tough about battery, but not the case this time. Battery is full and healthy. Starting to think i about fuel system. As i filled up full tank just day before and got home from work (30 miles) and next morning it didn't start.Any ideasThanks Quote Link to comment Share on other sites More sharing options...
Adam Posted November 2, 2013 Share Posted November 2, 2013 providing your fuel is getting through to the engine I'd be checking your sparkplugs what colour are they, are they actually sparking? Quote Link to comment Share on other sites More sharing options...
megawatt Posted November 2, 2013 Share Posted November 2, 2013 Drain fuel into clear container. Look for water and crud. Quote Link to comment Share on other sites More sharing options...
Stu Posted November 2, 2013 Share Posted November 2, 2013 this happened to a mate of mine so I ended up sorting it out for him it turned out to be the plugs on his!! new plugs and all was well Quote Link to comment Share on other sites More sharing options...
Smokin Joe Posted November 2, 2013 Share Posted November 2, 2013 Plugs would be my first port of call too. They are service items that need replacing several time in the life of a bike and were something that was routinely checked in the past but tend to be neglected these days because the tank needs to come off to get them out. Quote Link to comment Share on other sites More sharing options...
Tango Posted November 2, 2013 Share Posted November 2, 2013 Kill switch?....... Sidestand switch?....... Quote Link to comment Share on other sites More sharing options...
mytrenis Posted November 2, 2013 Author Share Posted November 2, 2013 Kill switch?....... Sidestand switch?....... good try yeah will try spark plugs and check fuel filter maybe thanks Quote Link to comment Share on other sites More sharing options...
Tango Posted November 2, 2013 Share Posted November 2, 2013 Kill switch?....... Sidestand switch?....... good try yeah will try spark plugs and check fuel filter maybe thanksYou'd be suprised how many times it's been those though mate.....ask one of our Mods about it......no names of course......cough, cough,TC, cough, cough....... Quote Link to comment Share on other sites More sharing options...
mealexme Posted November 3, 2013 Share Posted November 3, 2013 Kill switch?....... Sidestand switch?....... I did this two days ago... New bike which was turning over but not starting. I tried push starting a few times, then looked at the kill switch.... I previously thought that if it was turning over then the kill switch was off because with my last bike when the kill switch was on it wouldnt turn over. Quote Link to comment Share on other sites More sharing options...
mytrenis Posted November 9, 2013 Author Share Posted November 9, 2013 Kill switch was first thing i check has happen to me on my first 125 years ago. Fliped the switch by accident while riding. Ended up in the middle of the road called my dad who came with a van and took it home where started taking it apart n Just changed the spark plugs and still the same thing. Starting to think its fuel that doesn't go though, but not sore. How i could check if fuel goes as it should ?thanks Quote Link to comment Share on other sites More sharing options...
Ricky Posted November 9, 2013 Share Posted November 9, 2013 Try starting it and then take the plugs out and see if they're wet if they're bone dry then it'll be no fuel going though Quote Link to comment Share on other sites More sharing options...
mytrenis Posted November 9, 2013 Author Share Posted November 9, 2013 no sore if i can do that. because to get accses to plugs i need to take of tanks and air box and disconnect all of them. is the any other way of doing it? Quote Link to comment Share on other sites More sharing options...
megawatt Posted November 9, 2013 Share Posted November 9, 2013 Do what I said earlier in thread? Just be careful with fuel. I had 1/2 gallon of water in my tank from a refuel once. Quote Link to comment Share on other sites More sharing options...
mytrenis Posted November 9, 2013 Author Share Posted November 9, 2013 Drained it. And there is no traces of water. Could it be that fuel doesn't get to where it needs. like fuel filter needs to be changed, but i read that it is build in to the fuel pump so all fuel pump would need to be changed. Quote Link to comment Share on other sites More sharing options...
Fozzie Posted November 11, 2013 Share Posted November 11, 2013 Did you fill it up with diesel by any chance?We've had that one before Good spark?Fuel lines clear?What happens when you try to bump start? Perhaps the starter isn't engaging properly. Quote Link to comment Share on other sites More sharing options...
