  • Sign up now
Hayabusa hump mod
Tankbag
There is a mod for the hump which basically allows storage inside the hump, you have to replace the four bolts with wing nuts which allows removal of the plastic section inside the hump, pic below. But, I figure undoing four wing nuts every time I want to get at stuff inside the hump will get tedious, my question to you good folks is if I cut a trapdoor in the plastic section to put a hinge and key in there would that weaken the structure to much ?? You thoughts are appreciated. Cheers.
http://i200.photobucket.com/albums/aa3/tankbag/humpmod.jpg
