Need side stand lowering......
Guest STORM
can anyone recommend a welder or someone who might be able to shorten my sidestand...
I had my bike lowered and the side stand was shortened but not quite enough as my bike is almost vertical when on it and I have to really think about which way round I park the damned thing - if there is even the slightest camber upwards the bike will fall over :shock: thus making my little grey cells work even harder trying to park it than ride it !!
Put it in First gear when you park up to keep it a bit more stable until you get it sorted (Sensible bit) :wink:
Buy a hacksaw (Silly bit) :lol:
I had a full suspension kit made by Kais in Atherton (they do the suzuki racing team suspension :) ) it was done for my height and weight -- they also dropped my forks as I didnt want to have them cut so I can put it back to spec to sell it (I have the original suspension tucked up safe n sound). The suspension that has been made for my CBF will also fit a Hornet which I can now rule out unless I buy an older version as the newer ones are even taller!!
They shortened the stand but after the last few ride outs and camping trips it has proven to be not enough as a tiny incline causes it to topple over irrespective of whether I leave it in first gear or not..... the domino effect is not very fetching!!! :roll:
i can weld but its a bit of a long way to weld from :?
geez just a bit!!.... no worries I will keep looking.... have thought of getting a second hand one from ebay and getting that cut with the thought of a new centre stand and doing the same as is impossible for me to put on centre stand as need to lift the bike up 3" more than before :cry: will get it sorted before spring
only a thought but wouldn't a normal bike shop have a shorter stand to replace the one you got--probably have something knocking about that would do it in workshop
didn't think of that!! :roll:
cheers will look into it.......
