benp1992 Posted November 27, 2013 Share Posted November 27, 2013 Hi all.I have a Kawasaki er6f 2006 model. And its leaking oil from the weep hole on the water pump. Both Mechanical seals have been replaced twice now and it still hasn't fixed it so i now have no idea what it could be. it only leaks when i go out for a ride and theres a good sized little puddle after once ive parked up. anyone got any ideas as ive drawn a blank. Thanks in advanceBen Quote Link to comment Share on other sites More sharing options...
megawatt Posted November 27, 2013 Share Posted November 27, 2013 Could be a bent pump shaft, dodgy bearing or casing. Expensive, but replace with brand new pump, with a warranty? Quote Link to comment Share on other sites More sharing options...
Stu Posted November 27, 2013 Share Posted November 27, 2013 Both mechanical seals? You only have 1 plus an oil seal If it's leaking oil then its a problem with the oil seal Quote Link to comment Share on other sites More sharing options...
benp1992 Posted November 27, 2013 Author Share Posted November 27, 2013 ah sorry meant both the mechanical and the other one. But seen as they have both been replaced twice i ruled them out. Someone said maybe a head gasket. May see if i can grab another water pump Quote Link to comment Share on other sites More sharing options...
Stu Posted November 27, 2013 Share Posted November 27, 2013 who has replaced them in the past?I have recently just done mine which I know is a different bike but it cost me £96 in parts as all sorts has to come apart if a "mechanic" has done it have they just bodged it Quote Link to comment Share on other sites More sharing options...
Tankbag Posted November 27, 2013 Share Posted November 27, 2013 Is that where the oil is coming from for sure ? try removing all oil off the outside with a rag then squirting talcum powder everywhere then run her for a short while ( stationary ) then look for a damp patch Quote Link to comment Share on other sites More sharing options...
benp1992 Posted November 27, 2013 Author Share Posted November 27, 2013 Yea it was a mechanic who came highly recommended. Yea im positive its coming from the weep as I've let it run and watxhed the drop form Quote Link to comment Share on other sites More sharing options...
Stu Posted November 27, 2013 Share Posted November 27, 2013 when he fixed it did it solve the leak? and its just started again?it looks easy enough on the ER you could always have a go yourself Quote Link to comment Share on other sites More sharing options...
benp1992 Posted November 27, 2013 Author Share Posted November 27, 2013 Yea then it started again a couple of weeks later. Have replaced them myself as well and didn't fix it. May jist go for a new pump Quote Link to comment Share on other sites More sharing options...
Stu Posted November 27, 2013 Share Posted November 27, 2013 big job to replace the pump and expensive!for it to leak in a few weeks there is a problem somewhere might be worth stripping it down and checking the shaft to make sure its not worn or something Quote Link to comment Share on other sites More sharing options...
