Guest Posted January 7, 2008 Posted January 7, 2008 Hi folks Im sort of at a loose end and need some advice please.I crashed my steed 9 days after getting it which was around the end of November.Since then Ive been waiting on various parts etc.Well Ive got them now and have set about repairing it myself.Ive replaced the damaged headlight and top fairing nosecone.I had to replace the clutch cover as it was holed when it hit the floor andthis is where Im having some problems.Ive connected the clutch cover which is a bit of a pig to do in itself.Seeing as I needed to hold the clutch cover, line up the spindle with theselector rod, whilst not creasing the gasket at the same time as lining upthe 2 marks on the actuator arm.My problem is this........I dont know exactly how to setup the clutch cable so that it engages and releases the actuator arm.The clutch lever is either too slack or too tight and it seems that when I doactually manage to locate a gear it wont release.Thus meaning the bike wont move even when the clutch lever is depressed.If anyone knows the R1 2007 slipper clutch setup it would be a great helpif you could guide me through the process so that I can get my machine on the tarmac again.Ta in advance.Alex. 8) Quote
Stu Posted January 7, 2008 Posted January 7, 2008 took all the slack out of the cable ?not got a hynes manual ? usefull at time like this on mine its a bitch to set up Quote
Guest Posted January 7, 2008 Posted January 7, 2008 I cant find a Haynes for the year of bike.Mind you if the cable setup is the same in the previous years then I would appreciate a scan of the page or something.With regards to the slack mate...... just when I seem to get the lever right the actuator arm is slack ferkin confusing Quote
Stu Posted January 7, 2008 Posted January 7, 2008 Mind you if the cable setup is the same in the previous years then I would appreciate a scan of the page or something. not sure who has an R1 on here is the arm on a spring ? it may need turning to take up the load on the spring if you know what i mean Quote
MissD Posted January 7, 2008 Posted January 7, 2008 Have a word with Scod, he has an R1, see if he knows........best of luck Quote
Guest Posted January 7, 2008 Posted January 7, 2008 I will take my camara over tomorrow and get as many piccs as I can,never taken much notice as its new bike and covered in plastic but willsee what I can do to help Quote
Voodoo Posted January 8, 2008 Posted January 8, 2008 Sorry, haven't been on for ages, this might help if you need a manual:-http://www.bethman.net/r1forum/manuals.html Quote
Guest Posted January 8, 2008 Posted January 8, 2008 Thanks for the reply folks.Ive had the bike picked up today as I dontsee me having enough time to fix it myself.So hopefully Ill be back on the streets 2moro nightat the latest. Alex. Quote
