I-AM-THOR Posted October 3, 2014 Share Posted October 3, 2014 Wheel disks and rear shock have some rustRight indicators flash very fast Thanks Quote Link to comment Share on other sites More sharing options...
Tango Posted October 3, 2014 Share Posted October 3, 2014 So long as the disks are not warped or excessively worn and the rear shock is not leaking and the linkages are not sloppy they should be ok.......but the right indicator could cause you some probs as the flashing should not be too fast, and should be the same both sides. I assume that all the bulbs are ok.....or are they LED? Quote Link to comment Share on other sites More sharing options...
Bonniebird Posted October 3, 2014 Share Posted October 3, 2014 The indicators on my Speed Four flash very fast but that is because they are LED and need some sort of relay but it passed MOT. They all flash at the same speed though. If you've one side or one light that is different then it could mean an electrical problem and that could result in a fail Quote Link to comment Share on other sites More sharing options...
I-AM-THOR Posted October 3, 2014 Author Share Posted October 3, 2014 Yes faster on one side. I read that they can do this if one of the bulbs goes. Is this true? The front right bulb needs replacing. Could also be electrical though cos the rear has some black on the bulb. But might be also due to its age. Quote Link to comment Share on other sites More sharing options...
Tango Posted October 3, 2014 Share Posted October 3, 2014 If one of the bulbs is out it'll flash faster on that side..... Quote Link to comment Share on other sites More sharing options...
Bogof Posted October 3, 2014 Share Posted October 3, 2014 Yes faster on one side. I read that they can do this if one of the bulbs goes. Is this true? The front right bulb needs replacing. There's your answer. Replace the bulb and it should cure your fault. Quote Link to comment Share on other sites More sharing options...
I-AM-THOR Posted October 3, 2014 Author Share Posted October 3, 2014 Thanks Quote Link to comment Share on other sites More sharing options...
