Glorian Posted October 15, 2014 Share Posted October 15, 2014 I know this topic has been posted before. But i already use a pinlock in my lid. It's worked fine for the most part a little misting on edges. But today it got really fogged up i almost couldn't see through it.Has anyone had this problem / Have a solution? Was thinking of taking it off and cleaning it but not sure if that would do anything. Quote Link to comment Share on other sites More sharing options...
Pete Posted October 15, 2014 Share Posted October 15, 2014 Cleaning it is worth a go. Can't hurt. Do you open it up slightly? Helps to get a draft through to keep it clear. Quote Link to comment Share on other sites More sharing options...
Stu Posted October 15, 2014 Share Posted October 15, 2014 remove and refit the pinlock adjusting it so it contacts the visor properly do not wet the pinlock it will expand and moving this to the right section too! Quote Link to comment Share on other sites More sharing options...
Glorian Posted October 15, 2014 Author Share Posted October 15, 2014 Took it off. gave the visor a clean. and the pinlock a wipe over and refitted so we will see how it goes.Sorry stu my bad ! Quote Link to comment Share on other sites More sharing options...
littlecat Posted October 15, 2014 Share Posted October 15, 2014 if its fogging up, you have a gap ( however minute ) between the pinlock and the visor....make sure the seal is in contact all the way around Quote Link to comment Share on other sites More sharing options...
