fq-craigus Posted October 27, 2014 Share Posted October 27, 2014 I have just been browsing YouTube and one of the reccomended videos was for a product called seal mate.It's a thin bit of flexible plastic with a hook bit on it and it's designed to remove the grit and grime from inside your fork seal causing it to leak. You remove dust seal, insert tool run round the fork tube a couple times, remove, wipe fork compress and wipe a few times and job done no more leak..... Obviously wouldn't work if seal is cream crackered but if it's just starting to go because of some crud then surely should work.Question is has anyone tried and had success? As I have a slight weep and for a fiver it could be worth a punt Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted October 28, 2014 Author Share Posted October 28, 2014 Well I bought one last night so I'll give it a go, think it's worth having in the tool box. I'll review my findings Quote Link to comment Share on other sites More sharing options...
tommo Posted October 28, 2014 Share Posted October 28, 2014 You can use a feeler guage pushed between the fork leg and the seal as per the utube vid Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted October 28, 2014 Author Share Posted October 28, 2014 I think I would rather hook the crud out of the seal with the tool rather than push it in with a deeper gauge thanks though pal Quote Link to comment Share on other sites More sharing options...
Zipster Posted October 28, 2014 Share Posted October 28, 2014 Yes I have one. Handy as a temporary fix but ultimately if the seals start to leak you should be thinking about changing them. Mine lives under the seat and has been used to reseat the seals a couple of times and it does what it claims to do but a feeler gauge is a good alternative as the hook really isn't all that effective. Quote Link to comment Share on other sites More sharing options...
ApolloMozart Posted November 3, 2014 Share Posted November 3, 2014 It may work if the fork surface is not damaged. in my case it didn't work because there was a small dent in the fork. Quote Link to comment Share on other sites More sharing options...
