bertieboy Posted November 1, 2014 Share Posted November 1, 2014 I have very little knowledge when it comes to engines etc, so this may seem a very simple straight forward thing for all you bikers.I have my sons Motorhispania RX50 ready for the MOT tues. But i want to try and do a service on it before or after the MOT.What things do i need to check/replace etc?What oils/fluids will i need to use?It has a AM6 50cc 2 stroke liquid cooled engine.Thanks in advance for any help! Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 2, 2014 Share Posted November 2, 2014 all you can do is check gearbox oil level as this is totally seperate from the engine being a 2 stroke,air filter clean and chain correct tension,all lights working,fork seals not leaking when you bounce them up and down holding brake on.Not much else you can do to a 2 stroke really as there is no oil filter for the engine being a 2 stroke Quote Link to comment Share on other sites More sharing options...
