Red Dragon Posted November 9, 2014 Share Posted November 9, 2014 My cb600f seems to be pulling slightly to the right. And i mean ever so slightly. Hardly that noticeable. But i do notice it. When im on a good straight road holding the bike riding in a straight line the handlebar seems angled slightly to the right.Is this something i can take a look at myself, first point of inspection? When the bike is stationary the handlebars sit straight ok.Excuse my newby question (lack of experience) Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted November 9, 2014 Share Posted November 9, 2014 Check the rear wheel alignment Quote Link to comment Share on other sites More sharing options...
Adam Posted November 9, 2014 Share Posted November 9, 2014 As above rear wheel alignment. Also check your tyre pressures. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted November 10, 2014 Share Posted November 10, 2014 If you are sure that the front wheel is aligned with the handlebars straight, then it can only be wheel alignment which is causing the issue (I'm assuming the bike has not been involved in a nmajor collision which has beent the frame). If the front wheel is not aligned correctly with the handlebars, then it will be a twist in the front forks - To cure this, just loosen off the lower yolk and give it a 'shake', it should straighten up easily - when aligned, just re-tighten to the recomended torque settings. Quote Link to comment Share on other sites More sharing options...
