125cc stroker bogging down
Hay all. Im pete and a newbie........ Been lurking for a while and now need a hand, hope you can help.
I bought a derbi senda baja from ebay as a non running project, i fitted a Chinese engine from a zongshen arizona as the old one was fubar.
The new engine runs fine until im out riding, its has a horrid bogging down feeling and wont go much more than 40mph.
Bizzar thing is, going down the slightest of hills and its fine but up the slightest hill and it boggs.... Most of what i have read online suggests that it could be running rich at higher rpms.
Would yoi guys and gals agree.
Its driving me mad not getting out and riding and i really hope it can be fixed.
http://tapatalk.imageshack.com/v2/14/11/30/b76f62f16687d60d0eb560b19a4abfb7.jpg
http://tapatalk.imageshack.com/v2/14/11/30/1818e3c3c3ccf9ae5a960ec014e2edd3.jpghttp://tapatalk.imageshack.com/v2/14/11/30/79283434eba55e6249cbf701cd79e163.jpg
Some pics to help out ( we all love pics) made the cradle my self at work
Its the original zongshen cdi ignition. Never thought to shut the fuel off, good plan will try that...
The carb is the zongshen one too with the original needle however i have put the throttle cable from the derbi into the zongshen slide, would tjis affect the needle hight?
It was running to lean after all i have richend up the carb by raising the needle a notch and its performance is much better now
Still had to push it home two miles after the clutch cable snapped
  • 1 month later...
Helloo dude you have had a look already but air leaks
Are you running a standard air box or k&n if the after market pod filter put a sock over it and try see if this helps it stop bogging as much
If you are running a pod filter what jet do you have fitted
If this isn't the case.
What is the spark like weak or bright blue
And what sprockets are you riding on may be some of the issue
Kin regards
  • Sign up now
