bertieboy Posted December 1, 2014 Share Posted December 1, 2014 Hi Guy's,For some reason my bike has now decided that it doesn't want to turn off?The bike is electric start only and starts fine once the ignition key is turned on, but when i turn the key to off, the enginge just keeps running?It has never done this before, it does not have a kill switch/button and has always turned off by the key.Any ideas what could be the cause of this please? Quote Link to comment Share on other sites More sharing options...
pointblank0 Posted December 1, 2014 Share Posted December 1, 2014 Maybe a bit of water in the ignition keeping the circuit closed? Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted December 2, 2014 Share Posted December 2, 2014 Sticking relay? Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted December 2, 2014 Share Posted December 2, 2014 Hi if the lights go off when you turn the key then l doubt it's electrical, more than likely your motor suffering from a term called pre ignition. First check the condition of your spark plug, make sure the tip is not burnt, if the plug runs to hot it can ignite the fuel before the spark is called for hence the motor will continue to run despite you switching off the engine. There's a read up here that go's into it a little bit further.http://ngkntk.co.uk/index.php/technical ... ion-range/A quick check if it possible is to try and remove the plug cap whilst the motor is still running, be careful not to burn yourself. Quote Link to comment Share on other sites More sharing options...
mealexme Posted December 4, 2014 Share Posted December 4, 2014 out of interest, how do you shut it off then? Do you have to deliberately stall it? Quote Link to comment Share on other sites More sharing options...
Fozzie Posted December 4, 2014 Share Posted December 4, 2014 Sounds like the ignition circuit is jammed on and in effect you've hot wired it! Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted December 4, 2014 Share Posted December 4, 2014 out of interest, how do you shut it off then? Do you have to deliberately stall it?Yep, the easiest way would be to stall it, clutch in select gear, squeeze up the front and rear brake and clutch out.here's a run away diesel engine for you https://www.youtube.com/watch?v=F3_x6HeIpQsUnlike an overheated spark plug or other which causes the problem a petrol engine. leaking engine oil into the cylinder through a broken seal or worn piston rings is the cause of the problem here on the diesel hence the smoke. These runaways keep going until they burn up all the engine oil or size. Quote Link to comment Share on other sites More sharing options...
