Guest Posted December 2, 2014 Share Posted December 2, 2014 Hi guys, new to the forumTried to start my bike this morning, however wouldn't turn over,when i used the ignition switch it sounds like its trying to turn over but just doesntopen the choke on it but it will not turn over,lights come on (ride with them on all the time)the N light is on so its in neutralAnnnnyone have any ideas? Quote Link to comment Share on other sites More sharing options...
RantMachine Posted December 2, 2014 Share Posted December 2, 2014 To clarify, can you actually hear the starter motor trying to turn the engine over, or just a clicking noise? If it's the latter then it could be the solenoid, the one on my Lexmoto has a tendency to rust.Failing that, worth checking the connection between the carb and the cylinder head. The rubber on mine split on one occasion, that didn't exactly make for easy starts (or anything else, for that matter).Either problem would be more likely to happen as the cold and wet sets in, so they're probably worth a check. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 2, 2014 Share Posted December 2, 2014 Thank you for the reply,it sounds like the starter motor is trying.....best way I can describe it would be an old car Tring to start while your applying the accelerateor. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 2, 2014 Share Posted December 2, 2014 Never mind!!!! My own stupidly, I knocked the kill switch last night hense it making all the right noises but not starting.....feel like a right muppet but glad it runs! Quote Link to comment Share on other sites More sharing options...
Adam Posted December 2, 2014 Share Posted December 2, 2014 Hahahaha it's happened to the best of us at some point or another! Quote Link to comment Share on other sites More sharing options...
Tango Posted December 2, 2014 Share Posted December 2, 2014 Glad it was an easy fix mate.......a lesson learned...... Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted December 3, 2014 Share Posted December 3, 2014 Most folk learn this when attending a bike meet or t'rally! Quote Link to comment Share on other sites More sharing options...
