Invisible_Man Posted December 5, 2014 Share Posted December 5, 2014 Hi,Another new problem. Fitted a new battery as the old battery was past its best. The bike now refuses to start. Goes through its checks and light goes out......No fault code for the TPS anymore. Can hear the fuel pump prime. Try to start bike on electric start nothing. There is a spark. Stop cranking it over and the fuel pump runs again....Should it do that?Took the injector out. First Crank it spits fuel out. Next crank nothing. Sick to death now and ive only had the bike 2 days!! Cheers,IM Quote Link to comment Share on other sites More sharing options...
ro51znw Posted December 5, 2014 Share Posted December 5, 2014 Did you put your acid in and fully charge your new battery first Quote Link to comment Share on other sites More sharing options...
Invisible_Man Posted December 5, 2014 Author Share Posted December 5, 2014 Yep acid in and charged. Tried another good battery and same problem. Just not my year Im Quote Link to comment Share on other sites More sharing options...
Guest Posted December 5, 2014 Share Posted December 5, 2014 Get it to a hill or someone to push you and bump start it. If it fires, let it run for a good 30-45mins and if it doesn't, come back! It was working before and you've only changed the battery so I'd at least suspect it hasn't charged to what it should before diving into more complicated issues such as the fuel pump. Quote Link to comment Share on other sites More sharing options...
Invisible_Man Posted December 5, 2014 Author Share Posted December 5, 2014 Hi,Its running after a bump start. ECU light now shows the TPS fault again too. This it had before and was running ok, albeit a bit lumpy on tickover.Other good thing is that its charging at 13.5v at 7RPM. Sounds good i think?Why did the bump start make it run? I'm gonna make a big assumption that the ECU reset itself after the battery was disconnected and needed the bike to be running to aquire its settings again....Big assumption.Cheers,IM Quote Link to comment Share on other sites More sharing options...
Guest Posted December 5, 2014 Share Posted December 5, 2014 I'll hazard a guess at your battery being not charged properly so didn't have enough in it to start, but I could be wrong. Could be a number of things but see if it starts on the ignition switch after it's been running. With a bump start you bypass a lot of the initial ignition, battery is not needed, nor starter motor. Did you change the TPS already? Quote Link to comment Share on other sites More sharing options...
Invisible_Man Posted December 5, 2014 Author Share Posted December 5, 2014 Hi,Thanks for the help.Not changed the TPS yet as i have run out of money Bills and food are a priority This will be changed after xmas when i have more time and patience Its been running for 10 minutes. Switched it off and it fired up first time. Hope it keeps firing up!! It was turning over, and failing to start, prior to the bump start until the battery died after too many tries!Cheers,IM. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 5, 2014 Share Posted December 5, 2014 Not changed the TPS yet as i have run out of money Well of course the fault code will still be there then LOL! It'll be fine until you can though I'd imagine. Might even be dirty and you *may* be able to clean it instead of buying a new one but not familiar with the sensor enclosure and weather it allows you to or not. Worth checking out. Its been running for 10 minutes. Switched it off and it fired up first time. Hope it keeps firing up!!Cheers,IM.It will, it was your battery. Quote Link to comment Share on other sites More sharing options...
Invisible_Man Posted December 5, 2014 Author Share Posted December 5, 2014 Thanks Don't mean to be a whiney B*tch lol Just a bit dismayed as i bought the bike to run me to work and save me money on petrol. Spending more on repairs now lolHave heard of faults on these bikes being caused by dodgey batteries but alas it wasn't that. TPS is secured by them security star shaped bolts (Dont know the name). Thanks again,IM Quote Link to comment Share on other sites More sharing options...
ro51znw Posted December 5, 2014 Share Posted December 5, 2014 There torq bits bud Quote Link to comment Share on other sites More sharing options...
Invisible_Man Posted December 5, 2014 Author Share Posted December 5, 2014 Hi,Yep i know I suppose my ineptitude with this new fangled EFI stuff is shining through lol Give me non EFI any day of the week! They have a little bit of metal in the middle of the bolt so a normal torx bit wont fit. Cheers,IM Quote Link to comment Share on other sites More sharing options...
ro51znw Posted December 5, 2014 Share Posted December 5, 2014 Ahhh ok i know what you mean Deepest apologies Quote Link to comment Share on other sites More sharing options...
Fozzie Posted December 5, 2014 Share Posted December 5, 2014 For the starting, battery wasn't charged enough for a strong spark.Most 125s will turn over but struggle to start as the spark won't be good enough. When you bump start you take the power going out to the starter motor out of the equation, you also spin the alternator producing a little bit of juice, which helps you. Quote Link to comment Share on other sites More sharing options...
