Harri Posted December 12, 2014 Share Posted December 12, 2014 Hi again guys. Everything seems to work as it should on my XF650 ... at a standstill. On the move all is okay so far with just a run of a mile or two. BUT, the rear brake is useless I said at a standstill because the back brake does bring the bike to a standstill from a roll. But on the road ... it was only when I used the back brake on its own without the front brake that I discovered it wasn't doing anything to slow the bike down ! The front disc looks quite shiny and is obviously working fine. The rear disc on the other hand looks a bit rusty and doesn't look as if it is being used by the pads.New disc, pads and fluid? Or is there something I can do or look at to see what is going on? And then take it from there.Barcud Quote Link to comment Share on other sites More sharing options...
Stu Posted December 12, 2014 Share Posted December 12, 2014 the rear caliper may be seized up and in need of a rebuild Quote Link to comment Share on other sites More sharing options...
Harri Posted December 12, 2014 Author Share Posted December 12, 2014 Hi Stu, so just go for a caliper rebuild. Basically take it apart, clean cylinders and renew seals. I will renew the disc I think as it is looks quite grubby. So is my shopping list, new seals, brake fluid and disc? The brake lever seems to work so that should be okay.Is there any benefit from renewing brake hoses or replacing with braided?Cheers. Quote Link to comment Share on other sites More sharing options...
Stu Posted December 12, 2014 Share Posted December 12, 2014 pull the caliper off and operate the lever first to see if the pistons are moving freely if they are then if probably doesnt been a rebuild also if its on sliders make sure these are nice and free you wont see much difference with braided hoses to be fair Quote Link to comment Share on other sites More sharing options...
Harri Posted December 12, 2014 Author Share Posted December 12, 2014 Cheers Stu, that's the next job on my list.Barcud Quote Link to comment Share on other sites More sharing options...
Tango Posted December 12, 2014 Share Posted December 12, 2014 Could possibly need the rear master cylinder rebuilding too......a kit for that shouldn't be too pricey...... Quote Link to comment Share on other sites More sharing options...
Harri Posted December 14, 2014 Author Share Posted December 14, 2014 I've ordered caliper seals for when I take the rear caliper off. I should be able to check out and clean the caliper pistons then. I might need pads if they check out no good. Is it best to renew disc as well if it doesn't look too good?If all fails at this end I will get a master cylinder kit.Does this sound like a logical plan?Barcud Quote Link to comment Share on other sites More sharing options...
Stu Posted December 14, 2014 Share Posted December 14, 2014 yup thats the route I would probably take although the disc should clean up Quote Link to comment Share on other sites More sharing options...
Harri Posted December 17, 2014 Author Share Posted December 17, 2014 Hi again. Well I removed the caliper and the piston didn't take too much pressure from the brake pedal to come out. So that seems to move freely enough. I gave it a rub clean and replaced it with the new cylinder seals. There seemed to still be a bit of meat on the pads though I couldn't see any marks to indicate excessive wear. How would you clean the disc, wire wool maybe?I was gonna give the brake a try out but the battery appears to be flat! Though as before the brake does bring the bike to a halt when the bike is pushed from a standstill.Barcud Quote Link to comment Share on other sites More sharing options...
Tango Posted December 17, 2014 Share Posted December 17, 2014 Did the caliper float ok on the pins? The ones on my Honda are seized solid, so even though the piston moves freely the caliper can't float and clamp both sides of the disk...... Are you sure it's rust on the disk and not pad material that's stuck to it? I cleaned mine up with a fine Garryflex block.......did the job ok..... Quote Link to comment Share on other sites More sharing options...
Harri Posted December 17, 2014 Author Share Posted December 17, 2014 Float? The caliper wasn't solid, there was a little movement. Could be as simple as pads so have ordered some.Garryflex? No heard of that one.Barcud Quote Link to comment Share on other sites More sharing options...
Stu Posted December 17, 2014 Share Posted December 17, 2014 is there a piston either side of the caliper or just the one? Quote Link to comment Share on other sites More sharing options...
Harri Posted December 17, 2014 Author Share Posted December 17, 2014 There is the one piston. There is hardly any marking on the disc from pads is something else I've noticed. Quote Link to comment Share on other sites More sharing options...
Stu Posted December 17, 2014 Share Posted December 17, 2014 sounds like the pins need a damn good lubing although from looking at pics on the net you should have removed the sliding pins when you took the caliper off so they cant be seized now! Quote Link to comment Share on other sites More sharing options...
Harri Posted December 17, 2014 Author Share Posted December 17, 2014 Hi, I didn't remove any pins!On a diagram I can see a shim. Looks like it is between a pad and the piston. I don't remember seeing a shim of any sort?Wotcha think? Quote Link to comment Share on other sites More sharing options...
Stu Posted December 17, 2014 Share Posted December 17, 2014 thats just an anti squeal shim nothing to worry about the pins are the bolts that hold the caliper on they should be long and a threaded end bit like these http://www.filtsai.com/accord/brake_rotors/caliper_pins_3.jpg Quote Link to comment Share on other sites More sharing options...
Harri Posted December 17, 2014 Author Share Posted December 17, 2014 I removed 2 bolts that hold the caliper on to the bracket. The only other pin goes through the top with what looks like a straight screwdriver head.I greased these bolts when I replaced them. One goes through a rubber sleeve.If the pads are worn I would expect a squeal when the brake is applied. Quote Link to comment Share on other sites More sharing options...
Stu Posted December 17, 2014 Share Posted December 17, 2014 well if you have greased that bolt then that should be fine you may need take it for a ride and test it Quote Link to comment Share on other sites More sharing options...
Tango Posted December 17, 2014 Share Posted December 17, 2014 Yeah.....sounds like you greased them ok, so they should be ok. The other pin is the pad guide pin, which should be smooth so the pads can move freely. The flat blade screw is normally just a small blanking plug......when it's removed you see the allen head on the end of the pin so it can be unscrewed using a hex key..... Bear in mind that the quality of brake pads varies a bit.......so the stopping power of some are not as good as others.... Quote Link to comment Share on other sites More sharing options...
Harri Posted December 17, 2014 Author Share Posted December 17, 2014 Thanks again chaps. The guy that sold me the bike must have had the same problem And to honest if for some stupid reason I was going full pelt and tried to stop in a hurry the front brake would probably have put me over the top in an effort to come to a halt mmmmmmmm. Not good. Quote Link to comment Share on other sites More sharing options...
Harri Posted December 18, 2014 Author Share Posted December 18, 2014 Okay, had a spin around the block and the rear brake is the same, useless!So, Brake fluid replaced, piston cleaned, new seals fitted, bolts greased. The next cheapest thing is the pads. These though may not be here until after Xmas now because of the time of year The next cheapest thing to change if pads make no difference is new cylinder kit. The final thing would be the disc.How about the adjustable linkage from the brake pedal to the cylinder? Could this make a difference?Barcud Quote Link to comment Share on other sites More sharing options...
Tango Posted December 18, 2014 Share Posted December 18, 2014 The adjustable linkage will only make a difference of you're running out of travel on the brake pedal.....if you've not got a lot of free play on the pedal I'd tend to leave it as it is...... Given the age of the bike, a master cylinder rebuild may not be out of the question.Mind you, I'm not sure what you're expecting from the rear brake........mine will not lock the rear wheel at speed, but most of the braking is done by the front brakes anyway..... The rear is only really effective for holding the bike on a hill or slow speed manouvring. Quote Link to comment Share on other sites More sharing options...
Harri Posted December 18, 2014 Author Share Posted December 18, 2014 Cheers Bob. When I apply the rear brake there isn't any noticeable difference no matter what speed I'm doing. I can apply the rear brake at a standstill and I'm still able to push the bike forward! When I took the GSX for a spin the rear brake definitely made a difference bringing me to a standstill. Brake cylinder kit sounds a good move if new pads don't change anything.Barcud Quote Link to comment Share on other sites More sharing options...
Tango Posted December 18, 2014 Share Posted December 18, 2014 Sounds like a plan mate..... Quote Link to comment Share on other sites More sharing options...
