bertieboy Posted December 13, 2014 Share Posted December 13, 2014 Hi guys,I'm pretty sure somethings not right with my sons Motorhispania RX50.It will not rev into the red and when it reaches between 35/40mph it feels really rough.It splutters at the top end of every gear although it seems like it wants to on further?It does blow a little blue smoke, but it is a 2 stroke engine.Surely this isn't right?Could it be the mixture being wrong or something else i could do to find out or cure this? Quote Link to comment Share on other sites More sharing options...
cockercas Posted December 13, 2014 Share Posted December 13, 2014 Is it carbed or EFI? Quote Link to comment Share on other sites More sharing options...
Ricky Posted December 13, 2014 Share Posted December 13, 2014 Same setup as my old Peugeot xr6, it's carbed. Quote Link to comment Share on other sites More sharing options...
Tango Posted December 13, 2014 Share Posted December 13, 2014 Have you replaced the spark plug.......2-strokes can foul the plug causing it to run rough at the top end. The RD350 that I had years ago wouldn't get over 80mph if the plugs had been in there for a couple of months, but would hit 100 with new plugs........obviously when tested on a private road...... Quote Link to comment Share on other sites More sharing options...
bertieboy Posted December 13, 2014 Author Share Posted December 13, 2014 It had a brand new spark plug last week.It was purchased as a none runner a few months back. It already had a replacement sports exhaust fitted, which was not fitted right. I put it in the garage for an MOT and after a few adjustments lights/wheels/New front disc/speedo cable etc, it passed.Iv'e only been out on it a few times since buying it, and it has always seemed the same. The only thing that i know is not right, is the choke cable comes out of the lever when i put it on/off, but seems to work. Could the choke being stuck on slightly cause loos of top end power?Could the mixture screw have been adjusted wrong so the mixture is too rich or poor?I am clueless with bikes, but would like to have this running nice for my son asap!I am willing to listen and try any ideas? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted December 13, 2014 Share Posted December 13, 2014 is the air filter clogged up? what colour is the plug when you take it out? basic setting for mixture is about 1 1/2- 1 3/4 turns out to get it to run then tune it slowly from there Quote Link to comment Share on other sites More sharing options...
bertieboy Posted December 13, 2014 Author Share Posted December 13, 2014 I haven't checked the air filter, the plug is still clean like new as the bike has only been out 2/3 times since it was changed. But it was running the same with the old plug. I will have a look at the mixture screw and adjust it to see if it makes any change.Thanks to all so far! Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted December 13, 2014 Share Posted December 13, 2014 the plug should be coated with carbon deposits and r ange in cloour from very light greyish to dark almost black sooty like condition it helps if we know colour range as well Quote Link to comment Share on other sites More sharing options...
ro51znw Posted December 14, 2014 Share Posted December 14, 2014 I have had a very similar issues with my bike, culprit was valve clearance.... It had none.I went through all the normal checks too plug, filters, carb, cdi, coil etc etc it was just an off chance ckeck that found the problem Quote Link to comment Share on other sites More sharing options...
bertieboy Posted December 14, 2014 Author Share Posted December 14, 2014 ro51znw Does that mean i need to change/replace the complete Reed Valve Block like the item below:http://www.ebay.co.uk/itm/Motorhispania ... 1e93ae80caOr can it be cleaned or adjusted? Quote Link to comment Share on other sites More sharing options...
Tango Posted December 14, 2014 Share Posted December 14, 2014 Erm......this is a 50cc bike.......it's supposed to be limited to 30mph........even with the limiter removed (not recommended) I would have thought 40mph wasn't bad for a 50cc. Don't believe the stories you hear of people getting 70mph out of their 50cc bike..... I think you're chasing moonbeams mate worrying about getting it to go faster......and possibly making the bike illegal for a 16 year old. Yes, I agree that limiting a bike to 30mph is crazy.......but that's the law...... Quote Link to comment Share on other sites More sharing options...
bertieboy Posted December 14, 2014 Author Share Posted December 14, 2014 I'm not trying to get the bike to go any faster, i just want it running right.The problem is that the bike feels like it is choking/spluttering when it gets to around 35/38mph. But that is without the throttle opened all the way. It also doesn't want to rev into the red or anywhere near it, and i was told that it should reach the red?It does feel like some sort of fuel blockage! As i understand that the faster you go the more the fuel is sucked through, but it doesn't seem to be getting through fast enough. Does that make any sense or am i way off the mark? Quote Link to comment Share on other sites More sharing options...
Tango Posted December 14, 2014 Share Posted December 14, 2014 Could be a partially blocked main jet, incorrect float height adjustment or the needle is set wrong.....or, as you say, some kind of restriction in the fuel line..... Quote Link to comment Share on other sites More sharing options...
Fozzie Posted December 15, 2014 Share Posted December 15, 2014 Let's start from the top...I take it that it didn't always splutter, so this is a change for the worse.It sounds fuel related or ignition. So first port of call, check the spark plug, and air filter.If both are A-ok then put them back, if not, get new ones.If they are ok you could give the carb a clean, and make sure it is set up correctly. Just give the jets a good clean, and ensure the needle is the correct height. As you say it splutters a good portion up the rev range, so it's either the main jet, or needle jet at fault if this is carb related. I'd see what colour the plug is, if its showing it running lean, the needle needs to move up a couple of notches, and the reverse for if it is running rich.If that doesn't solve your problem it could be the main jet is blocked. Give it a good blast and then put the bike back together.If all that doesn't work and you do the cheap stuff, like spark plug, air filter, carb clean, clean the reeds, and so on then it could be expensive.It could be a packed in ignition coil that is failing at higher output, or it could be the bikes crank case seals have failed and you have reduced fuel pressure.That's about everything it could be 2-stroke related Quote Link to comment Share on other sites More sharing options...
