Harri Posted January 3, 2015 Share Posted January 3, 2015 It dropped out of the crankcase cover when I took it off?P.s. ah, this is the pin, check the pics out on the link. Just screws to find then?http://www.ludd.luth.se/~joshua/xf650/xf650.html Quote Link to comment Share on other sites More sharing options...
megawatt Posted January 3, 2015 Share Posted January 3, 2015 Should be a spring as well. Quote Link to comment Share on other sites More sharing options...
Harri Posted January 3, 2015 Author Share Posted January 3, 2015 Okay thanks Mega. I'll check out a parts diagram and surf the net and see just what is missing. I'm crossing my fingers that I'll find something dropping out of the sump. The oil looks pretty clean so maybe bits have dropped out with the last oil change and the seller wasn't aware of it. Otherwise I'll just have to hope that other parts aren't lurking around somewhere Barcud Quote Link to comment Share on other sites More sharing options...
megawatt Posted January 3, 2015 Share Posted January 3, 2015 Almost certainly won't come out with the oil, loads of webs and baffle plates in some sumps. I'd remove the sump plate itself, after buying a new gasket or at least some sealant. The missing parts should be in there somewhere. Quote Link to comment Share on other sites More sharing options...
Harri Posted January 3, 2015 Author Share Posted January 3, 2015 Blimey never thought about that I guess if the bits, 2 screws and a spring, are in there they should stay there and cause no harm? What if ... what if I dropped a magnet in on a wire, that might pick something up? Quote Link to comment Share on other sites More sharing options...
megawatt Posted January 3, 2015 Share Posted January 3, 2015 Maybe, probably not. Quote Link to comment Share on other sites More sharing options...
