markiedorg9999 Posted January 7, 2015 Share Posted January 7, 2015 on the way to work this morning my headlight and side light went of at first i thought blown bulb or popped fuse but checked all them and they were ok but then few minutes later it all came back on working again anyone o what it could be Quote Link to comment Share on other sites More sharing options...
Tango Posted January 7, 2015 Share Posted January 7, 2015 Sounds like a dodgy connector around the headlamp unit.....or possibly a bad earth connection around there. I assume the rear/brake light was ok? Quote Link to comment Share on other sites More sharing options...
markiedorg9999 Posted January 7, 2015 Author Share Posted January 7, 2015 yeah the rear was fine and all the indicators Quote Link to comment Share on other sites More sharing options...
Tango Posted January 7, 2015 Share Posted January 7, 2015 Without a wiring diagram I'm guessing, but there's probably a connector that goes to the headlamp, so check the condition of that first.... Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted January 7, 2015 Share Posted January 7, 2015 There will be a 'live' feed to the headlight and switched earth feeds in return.As both went off together - it is 99% likely that it is the feed that is dodgy - check all connectors for tightness and/or corrosion. Quote Link to comment Share on other sites More sharing options...
markiedorg9999 Posted January 9, 2015 Author Share Posted January 9, 2015 will do thabks Quote Link to comment Share on other sites More sharing options...
