soll Posted January 20, 2015 Share Posted January 20, 2015 right i have decided i want a tail tidy on my 125.any suggestions on how to find a correct fitting one.BIke Kymco CK1 125 2014 any ideas? Quote Link to comment Share on other sites More sharing options...
maccy Posted January 22, 2015 Share Posted January 22, 2015 If you cant find one for your bike, just get a universal one.You might have to drill holes in the right places though Quote Link to comment Share on other sites More sharing options...
mealexme Posted January 22, 2015 Share Posted January 22, 2015 You could do what I've done with the RR and simply remove the current set up and replace it with stainless steel L brackets from your local DIY store to connect the plate to the bike. The angles should be just about right. As for the indicators, you have a few options. Do what I did and get some sheet metal to make your own brackets and find a bolt somewhere that you can connect it to. before:after:Or, try and glue/tape/velcro another set of L-brackets to the rear of the plate and attach the indicators to thatOh, and the number plate is a tiny bit smaller that it was before, but shhh Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted January 22, 2015 Share Posted January 22, 2015 You could do what I've done with the RR and simply remove the current set up and replace it with stainless steel L brackets from your local DIY store to connect the plate to the bike. The angles should be just about right. That's pretty much what I did for my track bike, bend up a small bit of aluminium sheet (8"x4" ish) with a couple of bolts to hold the plate on and a couple more to secure the holder to the tail. If I'd thought about it, I'd have bent a couple of tabs for the indicators but it doesn't have any of those at the moment. Quote Link to comment Share on other sites More sharing options...
soll Posted January 22, 2015 Author Share Posted January 22, 2015 cool if the weathers pleasant enough this weekend ill take some pictures and take off some bits to see whats holding it all together. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 22, 2015 Share Posted January 22, 2015 Oh, and the number plate is a tiny bit smaller that it was before, but shhh Watch out you'll get alot of shit from people on here about that Quote Link to comment Share on other sites More sharing options...
