skiffer Posted February 4, 2015 Share Posted February 4, 2015 So this gsf 600 I have... I'm looking at them pretty cone shaped filters k & n do also ram air?? any ideas as to how these work... I know where they go, but do you remove the air box and they replace that?? I'm a little confused. Surely if I removed the box then nothing would hold take the rear side weight of the carb and it'd all be hanging off the actual engine. Or am I missing something .... or everything Quote Link to comment Share on other sites More sharing options...
Stu Posted February 4, 2015 Share Posted February 4, 2015 forget it keep the airbox and fit a K&N in that removing the airbox screws the fuelling and its a right twat to get set back up Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 4, 2015 Author Share Posted February 4, 2015 Well that was easy. Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted February 4, 2015 Share Posted February 4, 2015 Unless you've got loads of time and cash to spend on dyno work and plan to do loads more mods to it I'd go with what Stu says.K&N panel filters are pretty good - they won't really give any power gains but they work out at quite good value if you're going to keep the bike for a while. Quote Link to comment Share on other sites More sharing options...
Tango Posted February 4, 2015 Share Posted February 4, 2015 Unless you fit a 6sigma jetting kit as well........ Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 4, 2015 Author Share Posted February 4, 2015 Again a lot of what I'm doing is to make the bike look pretty.. not massively enthused by power gains etc. First big bike, done intend it to be my last or.... me be it's last if you get me. Quote Link to comment Share on other sites More sharing options...
mattycoops43 Posted February 4, 2015 Share Posted February 4, 2015 "any ideas as to how these work.."Well, you fit it, stand back and go 'oooo that looks pretty', then you fire it up and think ' oh, it's a bit lumpy at tickover now', then you go for a ride and think 'oh, it's not pulling like it did before'. Maybe it needs a service.Then you run it for a while, and the oil on the filter picks up dust as it should and it starts to richen up (assuming you don't strip it and clean it about once a month as it's now an exposed filter) so it goes better for a while, then it gets more dirty and it starts to run like a bag of poo as the filter gets more and more dirty, then you think, sod this, can't be bothered with the hassle and you fit the original back on and get an immediate power boost and reliability increase.They know what they are on about those Japanese guys! Quote Link to comment Share on other sites More sharing options...
Stu Posted February 4, 2015 Share Posted February 4, 2015 They know what they are on about those Japanese guys! I'm not Japanese Quote Link to comment Share on other sites More sharing options...
GazW Posted February 4, 2015 Share Posted February 4, 2015 Again a lot of what I'm doing is to make the bike look pretty.. not massively enthused by power gains etc. First big bike, done intend it to be my last or.... me be it's last if you get me. Look pretty? Shouldn't have got a bandit then.As stu says, stay away from the airbox, hundreds of threads on the bandit forum of people who've tried and f**ked up the fuelling.Spend your money on a set of weighted fork springs, and the rear shock off a 2004 cbr600rr, both will bolt in in a matter of hours and transform the bike, it will still look the same, but it will handle better on a B road. Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 5, 2015 Author Share Posted February 5, 2015 Again a lot of what I'm doing is to make the bike look pretty.. not massively enthused by power gains etc. First big bike, done intend it to be my last or.... me be it's last if you get me. Look pretty? Shouldn't have got a bandit then.As stu says, stay away from the airbox, hundreds of threads on the bandit forum of people who've tried and f**ked up the fuelling.Spend your money on a set of weighted fork springs, and the rear shock off a 2004 cbr600rr, both will bolt in in a matter of hours and transform the bike, it will still look the same, but it will handle better on a B road.Did you just call my bike.... ugly!! [emoji86] Quote Link to comment Share on other sites More sharing options...
Glorian Posted February 5, 2015 Share Posted February 5, 2015 Again a lot of what I'm doing is to make the bike look pretty.. not massively enthused by power gains etc. First big bike, done intend it to be my last or.... me be it's last if you get me. Look pretty? Shouldn't have got a bandit then.As stu says, stay away from the airbox, hundreds of threads on the bandit forum of people who've tried and f**ked up the fuelling.Spend your money on a set of weighted fork springs, and the rear shock off a 2004 cbr600rr, both will bolt in in a matter of hours and transform the bike, it will still look the same, but it will handle better on a B road. Oi.I happen to think my bandit looks nice. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2015 Share Posted February 5, 2015 Again a lot of what I'm doing is to make the bike look pretty.. not massively enthused by power gains etc. First big bike, done intend it to be my last or.... me be it's last if you get me. Look pretty? Shouldn't have got a bandit then.As stu says, stay away from the airbox, hundreds of threads on the bandit forum of people who've tried and f**ked up the fuelling.Spend your money on a set of weighted fork springs, and the rear shock off a 2004 cbr600rr, both will bolt in in a matter of hours and transform the bike, it will still look the same, but it will handle better on a B road. Oi.I happen to think my bandit looks nice.Someone's got to Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 5, 2015 Author Share Posted February 5, 2015 ........The bandit envy is strong here!! It's ok. We understand. Quote Link to comment Share on other sites More sharing options...
Glorian Posted February 5, 2015 Share Posted February 5, 2015 Phil you sod! Quote Link to comment Share on other sites More sharing options...
GazW Posted February 5, 2015 Share Posted February 5, 2015 ........The bandit envy is strong here!! It's ok. We understand.http://tapatalk.imageshack.com/v2/15/02/05/eccd345f23f553a68ffbe7d7f552e124.jpgI feel well placed to have that opinion.. Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 6, 2015 Author Share Posted February 6, 2015 Is there anywhere to give feedback on retailers?? Positive in this case. For delkevic Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted February 6, 2015 Share Posted February 6, 2015 Is there anywhere to give feedback on retailers?? Positive in this case. For delkevicYeah, what you do it start up a new thread and then, most importantly WRITE A LONG AND WINDING REVIEW IN CAPITALS REPEATING OVER AND OVER AGAIN THE NAME OF THE ENITITY YOU ARE ENDORSING WHILE NOT PUTTING ANY PUNCTUATION IN TO YOUR PROSE IT'S IMPORTANT THAT YOU REPEAT THE NAME SEVERAL TIMES SO THAT PEOPLE KNOW WHO YOU ARE TALKING ABOUT PEOPLE WILL ENJOY THIS AND DEFINITELY BUY THE THING OR SERVICE THAT YOU ARE RECOMMENDING WITH YOUR RAMBLING AND UNNECESSARILY LONG PARAGRAPH YOU MAY INCLUDE SOME SPELLING MISTAKES TOO THANKYOU Quote Link to comment Share on other sites More sharing options...
Glorian Posted February 6, 2015 Share Posted February 6, 2015 Is there anywhere to give feedback on retailers?? Positive in this case. For delkevicYeah, what you do it start up a new thread and then, most importantly WRITE A LONG AND WINDING REVIEW IN CAPITALS REPEATING OVER AND OVER AGAIN THE NAME OF THE ENITITY YOU ARE ENDORSING WHILE NOT PUTTING ANY PUNCTUATION IN TO YOUR PROSE IT'S IMPORTANT THAT YOU REPEAT THE NAME SEVERAL TIMES SO THAT PEOPLE KNOW WHO YOU ARE TALKING ABOUT PEOPLE WILL ENJOY THIS AND DEFINITELY BUY THE THING OR SERVICE THAT YOU ARE RECOMMENDING WITH YOUR RAMBLING AND UNNECESSARILY LONG PARAGRAPH YOU MAY INCLUDE SOME SPELLING MISTAKES TOO THANKYOU I yelled this in my head. Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 6, 2015 Author Share Posted February 6, 2015 Is there anywhere to give feedback on retailers?? Positive in this case. For delkevicYeah, what you do it start up a new thread and then, most importantly WRITE A LONG AND WINDING REVIEW IN CAPITALS REPEATING OVER AND OVER AGAIN THE NAME OF THE ENITITY YOU ARE ENDORSING WHILE NOT PUTTING ANY PUNCTUATION IN TO YOUR PROSE IT'S IMPORTANT THAT YOU REPEAT THE NAME SEVERAL TIMES SO THAT PEOPLE KNOW WHO YOU ARE TALKING ABOUT PEOPLE WILL ENJOY THIS AND DEFINITELY BUY THE THING OR SERVICE THAT YOU ARE RECOMMENDING WITH YOUR RAMBLING AND UNNECESSARILY LONG PARAGRAPH YOU MAY INCLUDE SOME SPELLING MISTAKES TOO THANKYOUIs that a no then... Quote Link to comment Share on other sites More sharing options...
Tango Posted February 6, 2015 Share Posted February 6, 2015 Erm.....I believe it's a bit of a piss take.....not of you, but another member whose use of caps lock has not gone unnoticed...... Were you thinking of where to post positive feedback on here or somewhere else? If you're thinking on here, then start a praise thread...... Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted February 6, 2015 Share Posted February 6, 2015 Yeah, sorry skiffer - that wasn't aimed at you - we have a serial yeller somewhere on the forum. It's always good to get a recommendation so please sing their praises! Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 6, 2015 Author Share Posted February 6, 2015 No apologies necessary. Delkevik, exhaust people. Well the Facebook person at least is awesome. No fuss replacement of part I destroyed by mistake. Quote Link to comment Share on other sites More sharing options...
Tankbag Posted February 6, 2015 Share Posted February 6, 2015 DID YOU KNOW IF YOU PRESS AND HOLD THE NUMLOCK KEY FOR ABOUT 5 SECONDS it makes a nice little up beep for CAPS ON AND A LITTLE DOWN BEEP for caps off, dead useful if you don't want to yell inadvertently. ( doesn't work on most laptops )Soz, off topic Skiffer save your money if you want more power get a 1200. Quote Link to comment Share on other sites More sharing options...
