Guest Posted February 5, 2015 Share Posted February 5, 2015 (edited) ok haha this will show how new to the scene I am. What is this called? And how much movement should it have?The reason I ask is because it feels a little wobbley, obviously it has the horizontal movement but also has some vertical wiggle aswell, is this right?http://i221.photobucket.com/albums/dd14/kc9400/10967813_10153619105269062_76026193_n_zpsg0rot63l.jpgAnother thing is I'm hearing a constant sort of ringing but not loud tone, it gets a bit louder when going quicker. Not sure if something is rubbing or whatnot.... It comes from the front of the bike. Edited February 5, 2015 by Anonymous Quote Link to comment Share on other sites More sharing options...
Fozzie Posted February 5, 2015 Share Posted February 5, 2015 Steering dampner...Leave it alone, if you find the handling ok and it isn't tank slapping... You're fine Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2015 Share Posted February 5, 2015 It's a steering damper. And should move freely. Though fixed securely at either end. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2015 Share Posted February 5, 2015 Cheers Foz and Shorty, see this is what happens when I start poking around. I look at bits and think "is that meant to do that?" Generally causing some paranoia that something is wrong when it's all normal Added a bit about some noise. Going to check the brake pads in a min. Hurry up lunch break. Quote Link to comment Share on other sites More sharing options...
Fozzie Posted February 5, 2015 Share Posted February 5, 2015 Possibly just the brake pads vibrating a bit, some copper grease on the back of the pads usually cures that issue.Other than that it could be the disc slightly rubbing on a pad but not enough to cause problems.If you try putting copper grease on the back of the front pads and it goes away, it eliminates that problem or at least pin points it better. Quote Link to comment Share on other sites More sharing options...
klingelton Posted February 5, 2015 Share Posted February 5, 2015 Possibly just the brake pads vibrating a bit, some copper grease on the back of the pads usually cures that issue.Other than that it could be the disc slightly rubbing on a pad but not enough to cause problems.If you try putting copper grease on the back of the front pads and it goes away, it eliminates that problem or at least pin points it better. qualify. DON'T PUT COPPER SLIP ON YOUR FRICTION MATERIAL!!! Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted February 5, 2015 Share Posted February 5, 2015 Possibly just the brake pads vibrating a bit, some copper grease on the back of the pads usually cures that issue.Other than that it could be the disc slightly rubbing on a pad but not enough to cause problems.If you try putting copper grease on the back of the front pads and it goes away, it eliminates that problem or at least pin points it better. qualify. DON'T PUT COPPER SLIP ON YOUR FRICTION MATERIAL!!! Silicon grease works better for the friction side..... (JOKING) Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2015 Share Posted February 5, 2015 So.... what you're saying is cover it in grease, cover it all in grease and play a game of 'Speed' but on a motorbike? I like it But yeah, on a serious note I'll take a look and give that a try. Thanks for the advice. Quote Link to comment Share on other sites More sharing options...
Fozzie Posted February 5, 2015 Share Posted February 5, 2015 Always good for the experience, and you can check if any brake caliper pistons are seized.As I said just a decent smear on the back of the pads. As above there is a big emphasis on getting that bit right! But if you cant tell the pad from its business end and backing then Id suggest picking up a book as it's as obvious as saying nightime, it's the dark part of the day Quote Link to comment Share on other sites More sharing options...
mealexme Posted February 5, 2015 Share Posted February 5, 2015 http://i.imgur.com/RQwlMCE.jpg Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2015 Share Posted February 5, 2015 ahahaha that sums it up. Darwinism even? Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted February 5, 2015 Share Posted February 5, 2015 Interesting how they can spell "lubricate" but can't manage "brakes"... Quote Link to comment Share on other sites More sharing options...
