sutty86 Posted February 13, 2015 Share Posted February 13, 2015 (edited) EveningAbsolutely peed offRode home for my meal break parked outside for thirty minutesWent to go back on ,keys in attempted to push start its trying to start but not turning overAnd guess what it has a missing kick start...Didn't come with the bikeTried pushing it but will not Still turn over...(quite difficult to push with clutch in)So now its parked outside my house open to the elements are the tea leaves...Anyone any ideas...Only thing I can think of was water ingress in maybe a wire under speedo (see previous post)Need to go find a kick start tomorrow if not or find a battery charger in petrol garageDon't think I can jump start from car...BTW is 2009 fuel injectedYbr customPints to anyone who can help ha****update****Thought it may be battery related but guess not ,trickle charged and battery is fine according to optimate and tried jump starting with leadsStill same outcomeLast time I rode I turned the engine off by kicking out the side stand(acts like a kill switch)Don't think it has anything to do with it but I'm trying to give as Much info as possPlease see link for what is happining Battery is Yuasa YTX7L-BS Powersport Motorcycle Battery Edited February 16, 2015 by sutty86 Quote Link to comment Share on other sites More sharing options...
Adam Posted February 13, 2015 Share Posted February 13, 2015 If you think it's electrical spray the offending area with wd40 it will disperse any water. When bump starting the bike you need to put it in gear and run with it and release the clutch then pull it back in as soon as the bike fires into life. Quote Link to comment Share on other sites More sharing options...
Six30 Posted February 13, 2015 Share Posted February 13, 2015 Hopefully some one will nick it Quote Link to comment Share on other sites More sharing options...
igingeee Posted February 13, 2015 Share Posted February 13, 2015 A kick start or bump start should only be needed when the correct start up procedure for your bike doesn't start the machine for whatever reason.Does the bike have no electric start?Also how did you get the bike started up until now? Quote Link to comment Share on other sites More sharing options...
Tango Posted February 13, 2015 Share Posted February 13, 2015 Battery knackered.......try charging it up......could've run down if you're only doing short journeys......otherwise check the charging..... Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 13, 2015 Share Posted February 13, 2015 Yeah get someone with a car to try n jump it... that's worked for me when the battery was the issue with my wr 125. If it's something else you'll soon know. Quote Link to comment Share on other sites More sharing options...
sutty86 Posted February 13, 2015 Author Share Posted February 13, 2015 Quick update tried bumping down some short steep hills and a long hill lights come on starts to whirr but won't start fully so cant give it gas's tried first and second gear...Yes has push start but won't turn over no lights come.on but its trying to turn over...You could be right about the potentially short journeysWill try get hold of a kick start or battery charger tomorrowWouldn't know what to do with jumping from carThanks Quote Link to comment Share on other sites More sharing options...
Tango Posted February 13, 2015 Share Posted February 13, 2015 Charge the battery and see how that goes...... Quote Link to comment Share on other sites More sharing options...
skiffer Posted February 14, 2015 Share Posted February 14, 2015 Jumping from a car would need leads from car battery terminal to your battery terminals. But everyone needs a battery charger with a bike... so as said by others go for charging either way to ensure it doesn't happen again. Quote Link to comment Share on other sites More sharing options...
sutty86 Posted February 14, 2015 Author Share Posted February 14, 2015 http://www.eurocarparts.com/mobile/battery-chargerWife's gonna buy me one for Valentine's up to twenty quidWhich would be the best betFeel free to suggest alternatives Quote Link to comment Share on other sites More sharing options...
Tango Posted February 14, 2015 Share Posted February 14, 2015 Personally I'd be going for something like this.... http://www.ebay.co.uk/itm/FZS-600-Fazer ... 1e826b6f6bCar chargers can be too much for bike batteries and can boil them if you're not careful..... Quote Link to comment Share on other sites More sharing options...
sutty86 Posted February 14, 2015 Author Share Posted February 14, 2015 Thank you , I genuinely thought they were a lot more to buy than that.Is there anywhere I can pay around that price and pick up this weekend.Don't want to goto halfrauds Quote Link to comment Share on other sites More sharing options...
Tango Posted February 14, 2015 Share Posted February 14, 2015 Well, they can be a lot more expensive....depending on the make and model.... You could try some bike shops, but I think you may not find a suitable bike charger for that sort of money locally.......but you never know..... Quote Link to comment Share on other sites More sharing options...
sutty86 Posted February 14, 2015 Author Share Posted February 14, 2015 Just found an optimate 3sp for fifteen pounds (used)What's the opinion on these Quote Link to comment Share on other sites More sharing options...
Tango Posted February 14, 2015 Share Posted February 14, 2015 I've got an Optimate 3.......seems to do the job nicely...... Quote Link to comment Share on other sites More sharing options...
sutty86 Posted February 15, 2015 Author Share Posted February 15, 2015 So put the bike on the optimate yesterday , left it for 24 hours came hack and the green light indicated it was fine and chargedTried starting and same problemUploaded this as I'm crap at describinghttp://youtu.be/cBuUG6DacowClutch is pulled in by the way(neutral is a bugger)Even tried with jump leads to car ,still the sameSo bit more informationWhen it was working last instead of turning off by key I kicked the side stand down which acts like a kill switchNot sure if that has anything to do it with...Thanks again sorry to be a pain Quote Link to comment Share on other sites More sharing options...
Paul-Kent Posted February 15, 2015 Share Posted February 15, 2015 Have you had plug out to see if there is a spark? Quote Link to comment Share on other sites More sharing options...
sutty86 Posted February 15, 2015 Author Share Posted February 15, 2015 No there is no tool kit with the bikeCould I use standard socket set? Quote Link to comment Share on other sites More sharing options...
Adam Posted February 15, 2015 Share Posted February 15, 2015 That rules out the battery then, check the side stand switch connections they'll be the wire that goes to the side stand. If that doesn't work check the spark by removing the spark plug and place it on the frame with the ht lead attached and press the started button it should spark a nice blue colour. P.s. Have you got any petrol? Quote Link to comment Share on other sites More sharing options...
Six30 Posted February 15, 2015 Share Posted February 15, 2015 (edited) Could still be a fooked battery , even though you charged it , a half knackered battery can cause your problem...... Check for a spark , check fuses and side stand switch... gather you checked it for petrol, if none of them I would try a new battery .See if you can borrow a volt meter, to test output of battery, if not ,turn your ignition on and press the horn ,if the tone is not as loud as it should be this could point to dodgy battery . Edited February 15, 2015 by Six30 Quote Link to comment Share on other sites More sharing options...
Paul-Kent Posted February 15, 2015 Share Posted February 15, 2015 I would of thought that the side stand switch would disable the starter all together?If the socket set has plug sockets then go ahead, normal sockets won't be deep enough Quote Link to comment Share on other sites More sharing options...
Six30 Posted February 15, 2015 Share Posted February 15, 2015 I would of thought that the side stand switch would disable the starter all together?If the socket set has plug sockets then go ahead, normal sockets won't be deep enough Would still turn over with bike in neutral. Quote Link to comment Share on other sites More sharing options...
sutty86 Posted February 15, 2015 Author Share Posted February 15, 2015 Thank you all for your adviceYes the bike has more than half fuel in.Double checkedNot sure how I'm going to get the socket outGoing to have to find a kit tomorrowAnyone know where I should check for side stand switch exactly Quote Link to comment Share on other sites More sharing options...
Ricky Posted February 15, 2015 Share Posted February 15, 2015 I would of thought that the side stand switch would disable the starter all together?If the socket set has plug sockets then go ahead, normal sockets won't be deep enough Would still turn over with bike in neutral. My bike doesn't turn over with the kickstand switch down or kill switch on Quote Link to comment Share on other sites More sharing options...
Six30 Posted February 15, 2015 Share Posted February 15, 2015 I would of thought that the side stand switch would disable the starter all together?If the socket set has plug sockets then go ahead, normal sockets won't be deep enough Would still turn over with bike in neutral. My bike doesn't turn over with the kickstand switch down or kill switch on I like to start bike let it warm up a bit on side stand while I'm getting geared up, so you can't do that ? Or do you have to put it on centre stand. Quote Link to comment Share on other sites More sharing options...
