Guest Posted February 15, 2015 Share Posted February 15, 2015 Okay guys i have a direct bike db50qt-a and I tried everything it was working yesterday fine until today. Today i cant start it with the kick start or the electric start it turns over but doesnt fire. I cleaned up the spark plugs and checked everything need help. The gap is right and the spark plug is newish. Quote Link to comment Share on other sites More sharing options...
Paul-Kent Posted February 15, 2015 Share Posted February 15, 2015 Is it actually sparking? Quote Link to comment Share on other sites More sharing options...
Tango Posted February 15, 2015 Share Posted February 15, 2015 Check to see if it's sparking, then check fuel system if you have a spark.....then check the compression if the other two are ok..... Quote Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2015 Share Posted February 15, 2015 No spark for some reason but there is compression but if was working yesterday at around 1 am and I tried starting it at 10am in the morning and it didn't work Quote Link to comment Share on other sites More sharing options...
Tango Posted February 15, 2015 Share Posted February 15, 2015 Start easy......try a new plug first and then see where you go...... Quote Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2015 Share Posted February 15, 2015 The plug is new but there isn't any spark Quote Link to comment Share on other sites More sharing options...
GazW Posted February 15, 2015 Share Posted February 15, 2015 The plug is new but there isn't any sparkNew or recent?Plugs can be duff from the off. If you haven't tried brand new one, go out and buy one. If that doesn't work, try a new spark plug cap and trim an inch of the HT lead before screwing the new one on. It's a case of trial and error in your case. If you start at one end and replace everything as you work back you're eliminating everything you've replaced. They are the most simple and cheapest things to replace in the ignition system. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted February 16, 2015 Share Posted February 16, 2015 very possibly the cdi unit or the pick up on the crankshaft both cheap enough to replace Quote Link to comment Share on other sites More sharing options...
sutty86 Posted February 16, 2015 Share Posted February 16, 2015 Try iridium plugWorked for meIs your ht lead clean Quote Link to comment Share on other sites More sharing options...
