RantMachine Posted February 24, 2015 Share Posted February 24, 2015 Hi again,As mentioned recently, I'm trying to get my old bike back up and running before the week is done. Got a new battery, but it's a bit different to the ones I've had before... Both bikes came with vented lead acid batteries, and I've got a Halfords Bike It Maintenance Charger for them. This new battery is of the sealed maintenance free variety, and I've read somewhere or other that some types of charger may not be suitable. Anyone able to comment whether my charger will be ok? Walking past Halfords later today so will get a new charger if necessary. It's cool, I didn't need to eat this week. Cheers in advance. Quote Link to comment Share on other sites More sharing options...
Joeman Posted February 24, 2015 Share Posted February 24, 2015 why does the new battery need charging? Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted February 24, 2015 Share Posted February 24, 2015 What Joe says.Although you should be fine with a maintenance type charger as it'll vary the voltage/current depending on charge state. Sealed batteries can go pop if you use old single stage chargers. Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 24, 2015 Author Share Posted February 24, 2015 Because I know sod all about batteries so I asked Google about them, and Google told me I'd need to do it This was the first page that came up when I did a search for info about batteries, goes on about sealed batteries being supplied at 70% charge and needing a charge up to full before use. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted February 24, 2015 Share Posted February 24, 2015 just fit it and see how well it turns the bike over ollie they are normally well charged and will start the bike and be usable from the box Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 24, 2015 Author Share Posted February 24, 2015 Will give it a go when the time comes, then. Bike isn't ready to fire up just yet. Quote Link to comment Share on other sites More sharing options...
Stu Posted February 24, 2015 Share Posted February 24, 2015 Fit it it should be charged And for reference the charger will be fine to use Quote Link to comment Share on other sites More sharing options...
Pete Posted February 24, 2015 Share Posted February 24, 2015 I've got a Halfords charger that might be the same as yours - has two switches allowing switching between sealed and...not sealed! Standard is the word I think it uses. Other switch allows switching between bike and car/other.You should be fine with a new battery as others have said. If you have a multimeter handy you could check the voltage before installing it just in case but that's probably overkill. Should be around 12.2V-12.8V. Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 24, 2015 Author Share Posted February 24, 2015 Dammithttp://intelisoftbd.net/user-post/wp-content/uploads/2014/07/facepalm,.jpgWhy did I not think of just using the sodding multimeter Quote Link to comment Share on other sites More sharing options...
Fozzie Posted February 24, 2015 Share Posted February 24, 2015 Most batteries are good to go out of the box, they will charge up just fine with a good run.If it's sealed then a battery charger usually has a softer setting to avoid making them gas, when they have no where for the gas to go (unless it's a gel battery). But in most cases a quick blast on any charger will be fine. Quote Link to comment Share on other sites More sharing options...
