ScreaminEagle Posted March 12, 2015 Share Posted March 12, 2015 Hi all,Managed to give my bike it's first run of the year today. Started first time and didn't miss a beat on about a 15 mile run. Got home, switched it off, wheeled it around the back, tried re-starting it, but it turned about half a crank then stopped as though the battery was dead. Tried a few more times but it just clicked.I decided to go and have a cuppa, then tried it about 20 mins later, and it fired straight up. Turned it on/off a few times without a problem, left it to warm up again, then it wouldn't start again until it cooled. Any ideas?It's a 2004 Honda CBR600 RR.Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 12, 2015 Share Posted March 12, 2015 measure across the battery whilst trying to crank it over and see what the voltage drops toit could be your battery on its way out or your starter motor drawing too much current when hot Quote Link to comment Share on other sites More sharing options...
ScreaminEagle Posted March 13, 2015 Author Share Posted March 13, 2015 Without trying to come across as stupid, and failing ;0) I have a multi-meter, but don't exactly know how to use it properly. Obviously I understand the -/+ but what do I set it to and what readings should I be expecting.Thanks. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2015 Share Posted March 13, 2015 Should be 12.6v+Does sound like the battery is about to retire... Quote Link to comment Share on other sites More sharing options...
Stu Posted March 13, 2015 Share Posted March 13, 2015 Not whilst cranking it over Phil Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2015 Share Posted March 13, 2015 Sorry, was just referring to fully charged voltage. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 13, 2015 Share Posted March 13, 2015 Yeah you need to forget fully charged readings in situations like this Quote Link to comment Share on other sites More sharing options...
ScreaminEagle Posted March 13, 2015 Author Share Posted March 13, 2015 Standard test from cold read 12.27v.While cranking the engine it dropped to about 4.8v, difficult to be accurate.With engine running at 2000rpm it fluctuated around 14.8v.Turned engine off and it read 13.06, but kept dropping at around a digit per second.So it sounds like the battery as had it then, yeah?Any recommendations on replacements?Thanks again guys. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2015 Share Posted March 13, 2015 Sounds that way mate... It's the most probable situation. How old is the battery, do you know? Quote Link to comment Share on other sites More sharing options...
Stu Posted March 13, 2015 Share Posted March 13, 2015 Yup I would be looking at replacing it to be honest You should be seeing above 9 volts when cranking Although your starter could still be suspect Quote Link to comment Share on other sites More sharing options...
Stu Posted March 13, 2015 Share Posted March 13, 2015 Easy way to check is if you have access to a car is to get it nice and warm till it won't start then jump it off the car battery Car not running If it starts then its your battery for sure Quote Link to comment Share on other sites More sharing options...
ScreaminEagle Posted March 13, 2015 Author Share Posted March 13, 2015 Not sure how old the battery is. It was on the bike when I bought it. There were some old receipts for various bits/work done to it over the last couple of years, but no mention of a battery.It almost didn't start from cold this morning, so definitely think it's had it. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2015 Share Posted March 13, 2015 Not sure how old the battery is. It was on the bike when I bought it. There were some old receipts for various bits/work done to it over the last couple of years, but no mention of a battery.It almost didn't start from cold this morning, so definitely think it's had it.£20 says it has If you get stuck in the meantime, you'll be able to bump/jump start it but a new battery should fix the start issue. Quote Link to comment Share on other sites More sharing options...
ScreaminEagle Posted March 13, 2015 Author Share Posted March 13, 2015 Not sure how old the battery is. It was on the bike when I bought it. There were some old receipts for various bits/work done to it over the last couple of years, but no mention of a battery.It almost didn't start from cold this morning, so definitely think it's had it. £20 says it has Lol...Are the 'gel' batteries worth it, or should I just stick with the acid type? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2015 Share Posted March 13, 2015 Not sure how old the battery is. It was on the bike when I bought it. There were some old receipts for various bits/work done to it over the last couple of years, but no mention of a battery.It almost didn't start from cold this morning, so definitely think it's had it. £20 says it has Lol...Are the 'gel' batteries worth it, or should I just stick with the acid type?Can't help you with that buddy... maybe someone else has experience of both... Quote Link to comment Share on other sites More sharing options...
Stu Posted March 13, 2015 Share Posted March 13, 2015 Gel or AGM all the way I will never touch a flooded lead acid battery again go for a motobatt Quote Link to comment Share on other sites More sharing options...
ScreaminEagle Posted March 26, 2015 Author Share Posted March 26, 2015 Hi all, been a while, but just a quick update.Fitted new agm battery today, and all is well again. :0)Thanks again. Quote Link to comment Share on other sites More sharing options...
Tango Posted March 26, 2015 Share Posted March 26, 2015 Glad you got it sorted mate...... Quote Link to comment Share on other sites More sharing options...
Guest Posted March 26, 2015 Share Posted March 26, 2015 Nice, thanks for updating. Quote Link to comment Share on other sites More sharing options...
