gaz73 Posted March 22, 2015 Share Posted March 22, 2015 2002 Italjet Formula 50 LCMy scooter failed its MOT recently due to excessive play in the handbars. I bought a new steering arm for £170 and theres still about 20% play left which may still fail.My problem is I dont want to spend £50 more on the steering head bearing or more on a wheel bearing etc unless I know for sure the play is coming from there.The play is only present when you move the handlebars in the usual direction to steer, if I push or pull the handlebars in any other direction there is no play, so could it be that the play is coming from the wheel bearing end or is it most likely the steering head end? is there some test you can do to determine the most likely suspect?If I cant get help I would need to spend another £100+ and cross my fingers.Thanks very much. Quote Link to comment Share on other sites More sharing options...
Edd Posted March 22, 2015 Share Posted March 22, 2015 I'm no expert, but I would have thought if there is play when you turn the bars..it would be the wheel bearing. But just my opinion, I'm sure someone a little more knowledgeable will be able to help! Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted March 22, 2015 Share Posted March 22, 2015 you can check the head bearings by putting bike on centre stand and getting someone to lean on the back of the bike to lift the front wheel off the floor then get hold of the forks down near the wheel and see if you have got any backwards and forwards movement and also while the front wheel is up in the air grab hold of it at the top and bottom and see if you can rock it side to side which will indicate wheel bearing problems Quote Link to comment Share on other sites More sharing options...
gaz73 Posted March 22, 2015 Author Share Posted March 22, 2015 you can check the head bearings by putting bike on centre stand and getting someone to lean on the back of the bike to lift the front wheel off the floor then get hold of the forks down near the wheel and see if you have got any backwards and forwards movement and also while the front wheel is up in the air grab hold of it at the top and bottom and see if you can rock it side to side which will indicate wheel bearing problems When I move the handlebars with the front wheel on the ground I still get the play, I can see that the front wheel isnt moving but the handlebars are. This is only very slight but its annoying, I dont know how much is too much basically. The front wheel does move slightly when off the ground but its like 0.1mm of movement and the bike doesnt have forks its a strange design, the suspension is totally separate from the steering. Quote Link to comment Share on other sites More sharing options...
