ginge511 Posted February 9, 2008 Posted February 9, 2008 Hello Since i got my aprilia rs125 running again it failed an mot ,and i also noticed it keeps cutting out when I'm either downshifting through the gears to a stop or setting off from 1st gear.Could it be that the mixture screw needs adjusting on the carb?I haven't touched that but that is the only thing i can see it being as there's a powwer problem too where i can't get passed 40 mph full revs just won't go past it at all? Quote
Voodoo Posted February 9, 2008 Posted February 9, 2008 How did you manage to get it running again Ginge and are you sure you didn't trap any fuel hoses when you put the tank back on? Quote
ginge511 Posted February 9, 2008 Author Posted February 9, 2008 How did you manage to get it running again Ginge and are you sure you didn't trap any fuel hoses when you put the tank back on?All's the running problem was when me and me dad fitted the exhaust he didn't make the gasket we used correctly so it didn't fire up.There's no hoses trapped from wheat i've checked and i've checked them several times.When It's coldish there's no powerloss at all but when it get's to sy 55c or above it losses power only at revs 3000 rpm and below? Quote
Voodoo Posted February 9, 2008 Posted February 9, 2008 Have you tried fitting a new spark plug? Quote
ginge511 Posted February 9, 2008 Author Posted February 9, 2008 Have you tried fitting a new spark plug?Bought a new spark plug 3 days ago mate.I don't know if the bike is derestricted or restricted yet and I've heard for the restricted version you mean a brg8-9 max and for the deristricted version you need a brg10 plug?I have the brg10 plug so this might be the incorrect one that's causing the problems? Quote
Voodoo Posted February 9, 2008 Posted February 9, 2008 Have you tried fitting a new spark plug?Bought a new spark plug 3 days ago mate.I don't know if the bike is derestricted or restricted yet and I've heard for the restricted version you mean a brg8-9 max and for the deristricted version you need a brg10 plug?I have the brg10 plug so this might be the incorrect one that's causing the problems? Maybe but I wouldn't have thought so, if you've still got the old plug give it a try see if that makes any difference Quote
ginge511 Posted February 9, 2008 Author Posted February 9, 2008 Have you tried fitting a new spark plug?Bought a new spark plug 3 days ago mate.I don't know if the bike is derestricted or restricted yet and I've heard for the restricted version you mean a brg8-9 max and for the deristricted version you need a brg10 plug?I have the brg10 plug so this might be the incorrect one that's causing the problems? Maybe but I wouldn't have thought so, if you've still got the old plug give it a try see if that makes any difference Will downgrading the sparkplug to a brg8 or brg 9 cause any harm even if I'ts deristricted and needs a brg10? Quote
Voodoo Posted February 9, 2008 Posted February 9, 2008 Different plugs run at different temperatures but thats all I know, I did put a different plug in one of my older bikes though and that always ran fine but I don't know if the plug would have been running hotter or colder. Quote
Guest Posted February 10, 2008 Posted February 10, 2008 The plug wont make any differenc eto the symptom, it sounds like you have an air pipe disconnected. Quote
R1 Iain Posted February 10, 2008 Posted February 10, 2008 viewtopic.php?t=8306I have put some info for you in the link aboveIain Quote
