Guest Posted February 13, 2008 Posted February 13, 2008 Hiya.Speedo light and turn signal indicator light have never worked. Bulbs are ok, so I'm gonna try and check the connections, and then the wires themselves with a multimeter.In the Haynes wiring diagram(below), whassat big bar the wires are going through?? Is it shorthand for a length of the wire or is it some sort of interface/block connector?Any advice, much appreciatedhttp://aycu33.webshots.com/image/42112/2006379421937123211_rs.jpg Quote
Voodoo Posted February 13, 2008 Posted February 13, 2008 Looks like a block connector to me, notice how one of the wires changes from Black to Black and Blue Quote
Guest Posted February 13, 2008 Posted February 13, 2008 Cheers for the prompt replies! I'll check the connectors first.Many thanks! Quote
Guest Posted February 16, 2008 Posted February 16, 2008 Found the connector block ok, inside the headlamp case. Nothing visually wrong, I'll have to buy a multimeter.Is a continuity check on a multimeter entirely passive to the bikes electrics? Quote
Guest Posted February 16, 2008 Posted February 16, 2008 If you mean, will it effect anything, then no it wont. Quote
houdini Posted February 16, 2008 Posted February 16, 2008 Basic sparkying? the red one usually goes bangany more help just ask Quote
