Throttled Posted November 1, 2015 Share Posted November 1, 2015 The Ghostbikes Motorcycle cover comes in four sizes and ranges (at the moment) from £16 to £22 plus delivery. It is also sold as Blacks Motorcycle cover on ebay. http://www.ghostbikes.com/12282-ghostbi ... large.htmlhttp://images.esellerpro.com/2189/I/107/657/5132-5135-Black-Sonar-Motorcycle-Rain-Cover-1600-0.JPGIt is the best fitting, easiest to get on and off bike cover I have found. It has vents, holes for the chain, a built in strap for underneath the bike and a heat proof section at the back. It is also totally waterproof. It may not last as long as more expensive ones (that I have not tested) but that is because it is so cheap. The fabric feels as thick as the other Oxford and R&G I have used, so it may well last as long as they did. Quote Link to comment Share on other sites More sharing options...
CGD217 Posted November 1, 2015 Share Posted November 1, 2015 Thanks Throttled!My R&G one is falling apart after 18 months of use so I think i'll look into replacing it with this one. Quote Link to comment Share on other sites More sharing options...
Hoggs Posted November 3, 2015 Share Posted November 3, 2015 I'm hoping my other half clears enough room in the garage to fit my bike in before the weather gets too bad... but based on experience I may put an order in as the one I have isn't very waterproof (more light drizzle proof!) Quote Link to comment Share on other sites More sharing options...
Throttled Posted December 11, 2015 Author Share Posted December 11, 2015 It has held up very well against the recent very bad weather. The strap has kept it in place and the bike has stayed dry. Quote Link to comment Share on other sites More sharing options...
Throttled Posted July 7, 2017 Author Share Posted July 7, 2017 The cover has split, but that is 18 months it has lasted, which is as much as I was getting out of more expensive covers. So, I have bought another, £18.99 delivered. Quote Link to comment Share on other sites More sharing options...
Lateralus Posted July 7, 2017 Share Posted July 7, 2017 I've been using one since January, and so far am very pleased with it. Heat-proof area has no problems going straight on a hot exhaust, although I did once misalign it and melt a little of the taped seam on my old bike. Also, the long bit of the strap is the wrong side for me needing to do it up from the right hand side. So, both user-related issues on my part!Bike seems very happy underneath it, in all weathers, and the large one fits over a Tiger and top box quite happily (albeit not down to the ground). Quote Link to comment Share on other sites More sharing options...
Throttled Posted July 7, 2017 Author Share Posted July 7, 2017 I think not going all the way to the ground helps with ventilation. I am sure corrosion issues ended because moisture is no longer trapped inside the cover. It fits a Versys 1000, just. I have to lower the screen to get the strap to clip under the bike. Quote Link to comment Share on other sites More sharing options...
