Using a gasket sealer on the carbs?
The Voyager
Hi, my assuming is this is not a good idea, should any 'globs' of sealer make their their way into the carb then shit really will hit the fan... :twisted:
The gasket kits for my carb are £35 each which come with all the different jets, but I only need the gaskets (or O Rings as they are called in my manual).
One idea was maybe trying to cut my own out of gasket paper but I figured they are not overly bad but have probably not been changed in its 25 year life span.
So sealer YAY or NAY? :popcorn:
Just buy a pack of nitrile o-rings for a tenner on Amazon. You get a load of sizes.
I also have a few sizes of o-ring cord for making up unusual lengths. Only a few quid/metre.
Gotcha. The papery/card type numbers?
If it's not broken or cracked, I'd reuse it. I don't use sealer on carbs because they're a sod to get back apart again.
I recently tried bog standard gasket paper to make up a float bowl gasket and it weeped fuel a bit - probably would have been better if I'd got the proper paper though.
  • 1 month later...
How come the Suzuki manual for my gsf600 says to use Three bond silicone for its cylinder head cover gasket?
I've used similar stuff before from Halfords and it was a bloody disaster, but I eventually managed to get some sort of gasket going.
Never, ever, never, ever use instant gasket seal on anything. Invariably, you will find bits of it clogging up parts of your engine that really do not need clogging. ;)
As with most things, its only as good as the person using it.
Never had any problems using 'Instant Gasket (silicone)'; Red or Blue Hermatite. I have also cut my own gaskets from both Cork sheets and sheets of 'greasproof' paper / oil paper.
:cheers:
:cheers:
Me neither have used them all in the past, but not on carbs though.
