Chain adjustment
scottynapalm
I bought mine from demontweeks because they had everything in stock! Delivered pretty quick and reasonable prices. You will need to check out the DID website to see what chain you need unless you've counted the links already :lol:
Other websites are available
Yeah....DID chain and sprocket set.....or DID chain and Renthal sprockets........have a look on eBay for your bike, because most of the suppliers have got eBay shops.....so you can compare prices easily...... :wink:
Mandp always screw up my orders so i dont recommend them at all. They sent one order out wrong 3 times.
Useless company and if you complain or leave them bad feedback they block you from trading with them on ebay.
DID make great chains, make sure you get an x ring chain or at least an o ring one, and make sure you get good steel sprockets not alu.
Its actually a pretty easy job, if you have a fitting tool and a chain breaker, dremel, angle grinder etc... You could probably buy all the kit for the same price as a garage would charge to fit a chain. :thumb:
I will be getting a man cave on the go when I move in to my new house at the end of March pal
  • 2 weeks later...
Yeah....sounds like you need a new chain and sprocket set on there mate..... :wink:
Got any recommendations pal ?
Tsubaki Alpha X Ring Gold Drive Chain - 525 - 112 Links from here:
http://www.bandcexpress.co.uk/buy/Tsuba ... 12.4A1#eq1
Plus set of sprockets. If you do mostly road not track you may even consider going 15 or even 14 teeth on the front sprocket too.
