Yzf
colindavey
Just for info Classickid the YZF-R125 has the same engine on all models and they all use injection :)
The Rieju copy called the RS3 used a carb on the engine.
The short answer is most likely, although if it doesn't there won't be a lot of fettling required to make it fit. The bikes shape has remained unchanged since it came out in 2008 aside from a few tweaks. The clocks have changed, and the forks are now upside down units. But the engine is the same so I expect the exhaust routing is also the same as it appears to have the same end can as previous years.
