Lumor_uk Posted April 15, 2016 Posted April 15, 2016 Have had old CG carbs apart but not willing to take the plunge with my bandit yet.Don't know if related or just coincidence after having fuel tank off to fix idle adjustment I messed up (eventually remember to reconnect vacuum hose to carbs) bike is now gargling low revs even when warmed up. Getting two outside plugs out (easier) one looks good the other carbon Fowled. Is that a good sign valve clearance and carb balance needs doing? Quote
eastanglianbiker Posted April 16, 2016 Posted April 16, 2016 whats the mileage and have you checked condition of air filter as well? Quote
Lumor_uk Posted April 16, 2016 Author Posted April 16, 2016 Air filter new, coming up to 15k miles Quote
eastanglianbiker Posted April 16, 2016 Posted April 16, 2016 if the valves sound quiet it might be worth just going with carb balancing,im assuming all the plugs are also new Quote
Lumor_uk Posted April 16, 2016 Author Posted April 16, 2016 Well after having the tank off and fixing my idle adjustment, new clutch cable it sounds like a tractor. looking closer I don't know if I'm pinching a vacuum hose on the left side. Will wait for my new inspection lamp to come after dropping the old one. Quote
Lumor_uk Posted April 17, 2016 Author Posted April 17, 2016 Fixed the tractor noise, he forgot to remind me to tighten the exhaust manifold after a few runs. One bolt missing. Quote
