How much can you adjust your throttle cable from the handlebar adjuster?
You might want to check the carb/throttle body - quite a few bikes have a secondary adjuster there if you're worried about maxing out the handlebar adjuster. That said, you should be fine with just a couple of turns in so long as it's not wobbly with the lock nut nipped up.
Yea I guess I can still try at the handlebars but I'm not very hopeful. Now just to find out how easy of a job it is locating the carb/throttle body :oops:
It is under the tank on the left, behind the frame, if I remember right. Probably a tank off job to get at them. Be very careful with the fuel connectors at the bottom of the tank. If it's like the S4 the originals are plastic and they go brittle over time. Mine are now replaced with metal ones.
