scottynapalm Posted May 28, 2016 Share Posted May 28, 2016 Hi gents got a CBR 600 RR with a all in 1 brake indicator unit. The brake light is lit but when I apply the brakes front/rear it's not getting brighter like it used to?? The indicators work fine. This is a LED unit. Any pointers on what might be the issue please? ScottySent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted May 28, 2016 Share Posted May 28, 2016 Dodgy switch?Is it the same with both from and rear brake? Quote Link to comment Share on other sites More sharing options...
scottynapalm Posted May 28, 2016 Author Share Posted May 28, 2016 Hi mate. Yeah same on both brakes?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tango Posted May 28, 2016 Share Posted May 28, 2016 Could be a dodgy connection to the light unit......or the light unit itself could be faulty...... Quote Link to comment Share on other sites More sharing options...
scottynapalm Posted May 28, 2016 Author Share Posted May 28, 2016 Will have to try get it stripped down in the next couple of days. Going to Manchester from exmouth on Friday [emoji23]Thanks pal[emoji1303]Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tango Posted May 28, 2016 Share Posted May 28, 2016 First thing I'd do mate is to put a meter from the brake connection on the light unit and the frame and measure the resistance.......when you operate the brakes the resistance should go low.....If it doesn't, then you've likely got a wiring issue or both brake switches are duff.....otherwise it's likely to be the light unit itself..... Quote Link to comment Share on other sites More sharing options...
scottynapalm Posted May 28, 2016 Author Share Posted May 28, 2016 That any good?http://uploads.tapatalk-cdn.com/20160528/47690b0bdd51aacb4d0ba7c5cb39153d.jpgSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tango Posted May 28, 2016 Share Posted May 28, 2016 Yeah, that'll do it...... Use the Ohms setting between the brake light connection on the wiring going to the light unit and the frame......you don't need the ignition switched on.....and operate the brake levers fully.....The resistance should go low when you pull the levers...... Quote Link to comment Share on other sites More sharing options...
scottynapalm Posted May 28, 2016 Author Share Posted May 28, 2016 Cheers pal. Will go at it later[emoji1303]Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stu Posted May 28, 2016 Share Posted May 28, 2016 I find it easier to just check you have voltage at the connector when you operate the brakes I have had false readings with resistance before But either way will work Quote Link to comment Share on other sites More sharing options...
scottynapalm Posted May 28, 2016 Author Share Posted May 28, 2016 Will do pal thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
scottynapalm Posted May 28, 2016 Author Share Posted May 28, 2016 Managed to half sort the problem. Both sensors are tits. Bogged the rear but I'm going to get the ordered now. It's in the garage with its Arse in its hand [emoji23][emoji23] thanks for the help ladsSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
scottynapalm Posted July 4, 2016 Author Share Posted July 4, 2016 Changed both sensors and adjusted the rear. As the rear light was constantly on[emoji23] thanks for the help ladsSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
