Bike not starting but is trying! Fuel injector issue on EML
Jogussy
Hi all, new to the site and having a bit of an issue with my 2015 Daelom VJ125 Roadwin R. My bike cut out whilst riding and won't start again. The EML is showing a fault with the fuel injector or injector circuit. The bike is trying to start but its like fuel isn't getting through. When first turning on the ignition key, the fuel pump isn't making its usual noise but don't know if the issue is with the pump or injector, etc. Any suggestions? I have had the fuel pump out and the motor is working when hooked up to the battery. Also had the fuel injector hooked up and this also seems to be working. Looked at the manual but it might as well be in a different language!! Sorry, I am a novice to this but keen to get it sorted myself! I am not a mechanic but i do have a bit of common sense and would like to know how to be able to sort it!
Yep....If it's still under warranty get it back to the dealer.
Otherwise.....you say the fuel pump motor works when you hook it to a battery, but you can't hear it when trying to start the bike? How does it get its power on the bike....is it through a relay? It sounds like a wiring/ electrical issue....... :wink:
Thanks both for your help. Wasn't sure how long the warranty would last as I have bought the bike from the first owner, only 2 months ago. Going to give them a ring tomorrow and see what they say. Wish me luck!
