Guest Posted September 26, 2016 Posted September 26, 2016 2 examples of it happening...- I'm riding and get to traffic lights, the idle goes way too low before eventually recovering Or this:https://vimeo.com/184295013Any ideas where to start? Quote
Tango Posted September 26, 2016 Posted September 26, 2016 I'd start with resetting the TPS......you can do this using TuneECU or by starting the bike and without touching the throttle leave it to idle for 10-15 mins and see how that goes..... TuneECU is worth getting for your bike......it's free and you only need to buy a OBD2 USB cable (£10 off eBay).....it'll let you monitor the sensors on the bike and see any error codes.....as well as loading ECU maps...... Quote
Guest Posted September 27, 2016 Posted September 27, 2016 I use TuneECU Im running my own custom map based off 10166, this issue has only just started happening but I haven't touched the map in months so I don't think it's something I've done Quote
Tango Posted September 27, 2016 Posted September 27, 2016 Hook up TuneECU and reset the TPS and see if that helps things.... Quote
TimR Posted September 27, 2016 Posted September 27, 2016 Triumph ... possible throttle body sealsWife had similar on 675 https://www.triumphtorque.com/messageboard/thread/145703-Got-an-air-leak-somewhere-2001-TT600.aspx" onclick="window.open(this.href);return false; closest i could get to the issue relevance Quote
Guest Posted September 28, 2016 Posted September 28, 2016 Hook up TuneECU and reset the TPS and see if that helps things.... I'll give it a shot this morning Triumph ... possible throttle body sealsWife had similar on 675 https://www.triumphtorque.com/messageboard/thread/145703-Got-an-air-leak-somewhere-2001-TT600.aspx" onclick="window.open(this.href);return false; closest i could get to the issue relevanceLink doesn't seem to load when on my phone, I'll try my laptop later.. thanks [emoji1360] Quote
ThePhatomfart Posted September 28, 2016 Posted September 28, 2016 What is your CO (idle trim) reading Quote
Guest Posted September 28, 2016 Posted September 28, 2016 What is your CO (idle trim) readingLast time I remember checking it was set to 19.1 on TuneECU Quote
Guest Posted September 28, 2016 Posted September 28, 2016 Booked on at 4pm at a local garage to get a CO reading, gonna take my laptop down and see if we can get it setup right Apparently 1-1.5% is factory but 2-3% CO is actually better but from factory they need to abide by omission rules etc. Quote
Guest Posted September 28, 2016 Posted September 28, 2016 All sorted [emoji4] Whilst I was plugged in to the garages CO reader I upped my CO using TuneECU to read around 2.5-3% (the old bike has 40k miles so struggles to hold a constant reading).All is well. Now pulls like a train and doesn't hesitate AT ALL at lights/when I stopped, which is such a relief as I hit loads of traffic lights on the way to Uni every morning. Map needs de-tuned a little now that the CO has been increased, but that'll take a few minutes on the laptop when I'm back home and can be bothered [emoji39] Quote
Stu Posted September 28, 2016 Posted September 28, 2016 That to me suggests something is allowing a leakage of air in to the throttle bodies and you may have just adjusted the co to compensate See TimR's reply If it's been working fine then just started then something is amiss somewhere Quote
Tango Posted September 28, 2016 Posted September 28, 2016 Did you reset the TPS while you had it hooked up to TuneECU? Quote
Guest Posted September 28, 2016 Posted September 28, 2016 (edited) That to me suggests something is allowing a leakage of air in to the throttle bodies and you may have just adjusted the co to compensate See TimR's reply If it's been working fine then just started then something is amiss somewhereI get what you're saying in that I may have just masked the issue, but since the CO was something like 0.5 and I've increased it to the recommended 2.5+ that can't be a bad thing? Did you reset the TPS while you had it hooked up to TuneECU?I did, plus a 10 minute idle but didn't solve anything. I done this at the garage whilst we waited for the bike to warm up prior to doing the CO but since it didn't help it, we went ahead and adjusted the CO to the recommended 2.5-3% Edited September 28, 2016 by Guest Quote
Tango Posted September 28, 2016 Posted September 28, 2016 Well.....if it's sorted it's all academic anyway.... Quote
Guest Posted September 28, 2016 Posted September 28, 2016 Well.....if it's sorted it's all academic anyway.... I've been out on the bike ever since! I absolutely have the bug again now that the bikes singing. I even skipped the gym today (I have a competition in 3 weeks so I probably shouldn't have) as I was just enjoying myself WAY too much. Quote
Tango Posted September 28, 2016 Posted September 28, 2016 Well.....if it's sorted it's all academic anyway.... I've been out on the bike ever since! I absolutely have the bug again now that the bikes singing. I even skipped the gym today (I have a competition in 3 weeks so I probably shouldn't have) as I was just enjoying myself WAY too much.Got your biking MOJO back then mate..... Quote
Stu Posted September 28, 2016 Posted September 28, 2016 That to me suggests something is allowing a leakage of air in to the throttle bodies and you may have just adjusted the co to compensate See TimR's reply If it's been working fine then just started then something is amiss somewhereI get what you're saying in that I may have just masked the issue, but since the CO was something like 0.5 and I've increased it to the recommended 2.5+ that can't be a bad thing? Its not a bad thing at the moment as it's now running right again But if it starts with the issue again I would investigate further Quote
Guest Posted September 29, 2016 Posted September 29, 2016 If it's been working fine then just started then something is amiss somewhereI've been thinking about this ever since, and the only thing I could suggest is possibly due to the scorching hot weather we had up in the NE this summer.. the bike was coping fine but since it's now back down to under 15 degrees the bike started showing the stalling signs. So maybe it was actually the hot weather that was masking the issue, and the cold weather actually brought it to my attention, to which it's (for now) rectified.... Maybe? Quote
