My partner has a Vauxhall Astra Estate and I am trying to buy spares for it but I can't figure out whether it is a MK IV or a MK V
It is a 2005 model but apparantly MK IV was made up to 2005 and MK V from 2005 onwards. I bought parts for the MK IV but they don't fit. I've tried putting VIN number and reg into search engines but nothing coming up. Any ideas how to find out?
2005 they made both the MK IV and MK V ... :?
I thought hers was the MK IV but the struts don't fit yet her tailgate and lights are not the MK V
Have you stuck the reg into eurocarparts or equivalent to see what comes up? I know you said Google buy wasn't sure if you'd tried a parts site
I've tried all sorts, Hoggs, but it never tells me the Mk. I even passed the VIN number through as many sites as I could get it in but again, lots of info I knew but no MK!
Maybe give vauxhall a call? Pretend you're going to buy from them then accidentally get "cut off" :lol:
Take it there's no part numbers on the stuff you need to replace?
Where did you order parts from , if you gave em the registration of car you should get the right parts.
Not always, if its a late registered model or on the change it can cross between them.
What are you trying to order phooey?
If he's bought parts for a mk IV and they don't then fit then it's a mk V.
Or a citroën
Is there no clue in the VIN?..... G = mk4.....H = mk5....?
Tango is correct. The Mk4 was known as Astra G and Mk5 was known as the Astra H.
Look underneath your probably see a big weld going right across the floor pan.
This is the thing Bob ... VIN has G in it suggesting MK IV but the headlights are like MK V. It was only the tailgate struts at £20 or so, so I'll buy MK V and see if tey fit. MK IV were too long!
Firstly, my condolences for owning a Vauxhall, secondly, it's a MK4 ;)
I don't ... my partner does. I own an Audi ... lol
It is only the tailgate struts ... about £20. MK IV were too long so I orderd MK V. And yes, 2005 is on the crossover!
Pah.....tailgate struts......get a bit of wood and cut it to length.....don't matter which mark it is then..... :wink: :lol: :lol:
