LondonRider Posted April 24, 2017 Share Posted April 24, 2017 Hi all, need some advice. My honda cbf 125 rear brake squeaks when I use it. But 2 things I have noticed is:1. It only squeaks at low speed2. It squeaks REALLY loud the first 2-3 miles of my journey in the mornings when commuting to work, but after that, it pretty much stops (or rarely happens).Does anyone know what could be up with it/does anyone have an explanation? The bike is a 2014 bike. Quote Link to comment Share on other sites More sharing options...
Westbeef Posted April 24, 2017 Share Posted April 24, 2017 Clean the rear drum, see if it stops Quote Link to comment Share on other sites More sharing options...
Invisible_Man Posted April 24, 2017 Share Posted April 24, 2017 It'll be brake dust. My CG125 used to do it now and again. Like Westbeef said you'll have to take it apart and give it a good clean. Sent from my thl T7 using Tapatalk Quote Link to comment Share on other sites More sharing options...
LondonRider Posted April 24, 2017 Author Share Posted April 24, 2017 Okay thanks. Looks like i'll be spending sunday taking it apart and putting it back together. Hope it isn't too complex! Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 25, 2017 Share Posted April 25, 2017 Okay thanks. Looks like i'll be spending sunday taking it apart and putting it back together. Hope it isn't too complex!Not complex but messy and hazardous. The best value brake cleaner can be found at Toolstation as well as gloves and face masks. They do a pack of Scotchpads as well that are really good for a job like this. Quote Link to comment Share on other sites More sharing options...
someone Posted April 25, 2017 Share Posted April 25, 2017 I had this, and did that, and it was easy.Obviously I was in a constant panic that my wheel would fall off but it never did.Get a Haynes manual, always useful to have, but it will take you through all the steps. And once you know how to get the wheel on and off you pretty much know how to replace brake shows and change the sprockets too! Quote Link to comment Share on other sites More sharing options...
LondonRider Posted April 25, 2017 Author Share Posted April 25, 2017 okay brilliant thanks guys. And yep got brake cleaner already, got WD40 brake cleaner! Quote Link to comment Share on other sites More sharing options...
exportmanuk Posted April 27, 2017 Share Posted April 27, 2017 Do it soon My son got a set of cheap shoes for his 125 and they started making lots of noise turn out the casting had broken and it was destroying the drum. Needed a new wheel.He was not happy Quote Link to comment Share on other sites More sharing options...
