Lrigh1977 Posted June 28, 2018 Posted June 28, 2018 Evening all,I recently brought a Tiger 800 after 9 years with no bike, I love it! Does anyone know what the pin on the bottom of the footrest is for? I’ve scraped it a couple of time on roundabouts hence was thinking of removing it. I did wonder it it’s a safety device warning me not to go any lower? Any advice would be very welcome. CheersLeigh Quote
Gerontious Posted June 28, 2018 Posted June 28, 2018 Thats about right.. my GS had them on the original pegs, then I replaced them and the new (lower) ones didn't have them. They're not crucial in any way. just to prevent damage to the pegs if you lean a little too far. Quote
Bender Posted June 28, 2018 Posted June 28, 2018 Most bikes have a ball or pointy bit on the pegs to catch before you put too much weight on it and loose the rear, unless it's a harley in which case you will just see the running boards going over your head just as you wonder why the sky is a green grassy colour. Quote
mikestrivens Posted June 28, 2018 Posted June 28, 2018 ... I did wonder it it’s a safety device warning me not to go any lower? ,,, Yes spot on. Quote
Snod Blatter Posted June 28, 2018 Posted June 28, 2018 AKA "hero blobs", most bikes have them and it is indeed a warning device that you're either about to grind something more expensive, run off the edge of a tyre or have an exciting time pivoting the bike on a foot peg at speed if they're solidly mounted.I hardly ever get near them Quote
mikestrivens Posted June 28, 2018 Posted June 28, 2018 AKA "hero blobs", most bikes have them and it is indeed a warning device that you're either about to grind something more expensive, run off the edge of a tyre or have an exciting time pivoting the bike on a foot peg at speed if they're solidly mounted.I hardly ever get near them Mine are as good as the day Triumph fitted them. Quote
Gerontious Posted June 28, 2018 Posted June 28, 2018 years ago, you could buy them made from something flint-like.. to create rather decorative trails of sparks. Quote
mikestrivens Posted June 28, 2018 Posted June 28, 2018 years ago, you could buy them made from something flint-like.. to create rather decorative trails of sparks. Cool Quote
fastbob Posted June 28, 2018 Posted June 28, 2018 Even my ER5 has them . You would have to be going some to scrape them on the deck though. Quote
Lrigh1977 Posted June 29, 2018 Author Posted June 29, 2018 Morning all,Thanks for all the responses, I absolutely want to stay safe hence will not be removing them. Thanks again for the swift replies Cheers Quote
Guest Posted June 29, 2018 Posted June 29, 2018 I don't know one how you are riding but might be worth leaning off a bit more so that you don't have the bike pushed over so far. Bikes like the tiger don't really encourage leaning off because of the riding position but it's still good practice in turns that have you scraping. There's always the small danger of the peg digging in or getting caught on a poor road surface and upsetting the bike mid turn. Quote
Lrigh1977 Posted June 29, 2018 Author Posted June 29, 2018 Thanks for the advice, I didn’t consider that. I do ride fairly upright, as you say it’s the style of the bike. I’m not trying to get my knee down or anything, just enjoy cornering I start the IAM training July 8th, I’m sure I’ll get of advise then too. Cheers Quote
Fozzie Posted June 29, 2018 Posted June 29, 2018 I used to want to get the attachments that give off blue or green sparks but end of the day you are marking the road so I gave up on that.They can cause the back wheel to step out still if you go over quite hard. I found this out on an Xj6 when mid-roundabout it grounded and caused quite a big wobble. It's always fun to find the leaning limit of the bike but don't push any harder or you tempt problems, if you want to lean further, raise the pegs slightly. Quote
