Foxy Stoat seeks Pig Posted July 10, 2018 Share Posted July 10, 2018 Ok so I have a long spell off work and may not even be able to ride again, real bad times, but to keep active I'm going to continue to tinker with my bike.I have a new motobatt battery to fit. I have a factory fitted yahama alarm, is there anything I need to take into consideration before changing the battery or is it a simple case of negative off, positive off swap battery and reconnect??Thanks all Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted July 10, 2018 Share Posted July 10, 2018 Sounds good, you might put a battery conditioner on if left for long periods with alarm on. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted July 10, 2018 Author Share Posted July 10, 2018 Thanks, good point, Hadn't even considered(trying not too) about the fact it might be left for months. Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted July 10, 2018 Share Posted July 10, 2018 Some alarms go off if you start tampering with the battery, disconnecting and reconnecting it, so.. Be ready for that with ear plugs or something. Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted July 16, 2018 Share Posted July 16, 2018 buy a solar charger for the battery, remove the fire risk and the expense. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted July 16, 2018 Author Share Posted July 16, 2018 buy a solar charger for the battery, remove the fire risk and the expense. Like it any recommendations? I had a look around but ideally I want a connection wire that is fixed to the battery rather than messing about with crocodile clips.Something like this one perhaps? https://www.ebay.co.uk/itm/battery-charging-12v-solar-panel-for-12-volt-batteries/150825687659?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649 Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted July 18, 2018 Share Posted July 18, 2018 Yeah that one, it was £15 from the now defunct Maplin. I installed a cigarette style female socket (Marine type) to the battery tucked under the seat, so I leave the solar panel on the roof, cable comes in through garage door and I connect bike it when I park it up. Quote Link to comment Share on other sites More sharing options...
