Slowlycatchymonkey Posted November 4, 2018 Share Posted November 4, 2018 Ive accidentally melted some plastic onto the exhaust. Forgot I had heated insoles and glove liners plugged in so they unplugged themselves when I got off the bike and because I was at a petrol station didn't step away from the bike- cue dangly wire coating melting onto the exhaust. Idiot.So Ive had a google and am thinking this is the solution (except they don't sell that particular product in this country), what do you think? Do it or steer clear?"> Quote Link to comment Share on other sites More sharing options...
Mickly Posted November 4, 2018 Share Posted November 4, 2018 Ive accidentally melted some plastic onto the exhaust. Forgot I had heated insoles and glove liners plugged in so they unplugged themselves when I got off the bike and because I was at a petrol station didn't step away from the bike- cue dangly wire coating melting onto the exhaust. Idiot.So Ive had a google and am thinking this is the solution (except they don't sell that particular product in this country), what do you think? Do it or steer clear?"> I did this when I dropped a microfibre cloth on the exhaust ( who knew microfibre cloths were made of plastic? - not me!! )Any way - the way I did it was by taking the worst of it off with wire wool then Autosol and plenty of elbow grease. Quote Link to comment Share on other sites More sharing options...
Bender Posted November 4, 2018 Share Posted November 4, 2018 If there is no plastic but just the residue ie nothing you can scrap or peel I would try pvc cleaner, but not the kind you get for cleaning window frames and plastic, the kind you clean pipes with before using solvent weld, it's a solvent and should fetch it off, nail polish remover and acetone also, try a small section, clean up with polish afterwards. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted November 4, 2018 Share Posted November 4, 2018 If it's plastic would cellulose thinners used on a cold exhaust soften it up enough to scrape off? Quote Link to comment Share on other sites More sharing options...
Guest Posted November 4, 2018 Share Posted November 4, 2018 Ive accidentally melted some plastic onto the exhaust. Forgot I had heated insoles and glove liners plugged in so they unplugged themselves when I got off the bike and because I was at a petrol station didn't step away from the bike- cue dangly wire coating melting onto the exhaust. Idiot.So Ive had a google and am thinking this is the solution (except they don't sell that particular product in this country), what do you think? Do it or steer clear?"> What is the exhaust - is it chrome or stainless steel? Either way, I would think twice before using wire wool - a very sharp blade (e.g. Swann-Morton - you will be used to these ) used in gentle precision mode and autosol probably the way forward...... Quote Link to comment Share on other sites More sharing options...
Tankbag Posted November 4, 2018 Share Posted November 4, 2018 Breakaway by premier cleaning products it's not abrasive ( smells of oranges) might not do it on burnt plastic but I've used it on adhesives on paintwork & left no marks on the paint, worth a try ? Quote Link to comment Share on other sites More sharing options...
fastbob Posted November 4, 2018 Share Posted November 4, 2018 If it's plastic would cellulose thinners used on a cold exhaust soften it up enough to scrape off?That would have been my first choice, however before you spend any money why not try good old petrol generously applied with a soft cloth ? Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted November 5, 2018 Author Share Posted November 5, 2018 Umm I don’t know what cellulose thinners are? Is that like acetone?I take it there are no supporters of the oven cleaner method? Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted November 5, 2018 Share Posted November 5, 2018 Umm I don’t know what cellulose thinners are? Is that like acetone?I take it there are no supporters of the oven cleaner method? You can buy it at an auto paint place. Halfords may sell it in smaller quantities. I buy it by the gallon for spraying classic cars. The thinners for Hammerite paints are similar but expensive. Older cars were sprayed using cellulose based paint so it’s not hard to find. Most auto factors should stock it. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted November 5, 2018 Author Share Posted November 5, 2018 Thanks. I think I’d rather try that first than go for an unknown quantity. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted November 5, 2018 Share Posted November 5, 2018 Just googled it, apparently Wilkos sell a small bottle for £3 Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted November 5, 2018 Author Share Posted November 5, 2018 Just googled it, apparently Wilkos sell a small bottle for £3 Thankyou Quote Link to comment Share on other sites More sharing options...
Tango Posted November 6, 2018 Share Posted November 6, 2018 Harpic bog cleaner....The 10x stuff in the black bottle......but you may want to try it on the underside of the exhaust first......just in case...... Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted November 6, 2018 Author Share Posted November 6, 2018 Yes I’m filled with trepidation about getting the plastic off and leaving a whole new type of mark. Not fancying grovelling around on floor trying to test and inconspicuous area at the mo and won’t be until it stops raining! Quote Link to comment Share on other sites More sharing options...
