How to remove sticky tape from rims ?
gogs01
I've had a search but can't find any tips, so apologies if it's been covered before.
After getting tyres fitted and re- balanced, the sticky tape used to hold the previous balance weights is left on the wheel and looks unsightly. What can I use to remove this sticky tape / glue ?
PS - WD40 hasn't worked ! :(
I used white spirit and a toothbrush.
You can get 10 child’s toothbrushes for £2 at B&M so use them for cleaning stuff then chuck away.
If they are soft enough for their teeth you won’t have to worry about scratching your wheel rims.
‘Sticky Stuff Remover’ available from lots of places including amazon. Has always worked for me.
Oohh good call.
I forgot I’ve got a bottle of that.
Used it to get the glue residue off my Step daughters Clio when I was replacing the rear window / door seal.
It kind of melted the old glue and it came off in sticky balls, a lot like snot but not as salty.
Oohh good call.
Remind me to decline the amuse-bouche at your place :D
........ a lot like snot but not as salty.....
Which begs the question "and how do you know?"
I first used this question to great effect when I was teaching a student who had just undertaken a particularly hot and strenuous breathing apparatus drill. As a consequence, he was drinking a large cup of the (admittedly disgusting) saline solution we used to use for rehydration after these exercises.
His comment was "effing hell this stuff tastes like monkey sp*nk". Cue question. Oh how we laughed.
This is the best stuff.
Apply with a brush leave for about 2 mins and scrape off with a credit card! Depending on finish Acetone or isopropyl alcohol to clean surface afterwards.
Many thanks for all the replies ! :D
I mentioned this when I was picking my bike up from my local Motorrad dealer. The salesman produced a bottle of "Tar and Glue" which he was good enough to use to clean the sticky tape residue from both my wheels. A short soak, brush with a toothbrush then clean off with a rag - et voilà - clean wheels !
So - Sticky Stuff Remover, or Tar & Glue to be sourced for next time ! :D
You guys are brilliant - I tried Google and couldn't find it. Now I know what it is and where to get it - thanks again !! :cheers:
