Evening, does anyone know of any bike that has a manual petrol tap that has ON , RES and most importantly OFF that is NOT attached directly to the tank but is bolted to the frame . I've already found one off a DR 800 , see pic . Any others ? Cheers.https://m.ebay.co.uk/itm/Suzuki-DR-800-SR42B-750-SR41B-Benzinhahn-Hahn-petcock/252753323263?_mwBanner=1&_rdt=1
Posted (edited)
Older ER5, but I wouldn't recommend one.
I wouldn't recommend one either, that's what I want to replace ! 😂 I need one with an OFF position to stop the thing flooding . ER5 taps are crap . They depend on a microscopic hole between the diaphragms that is all too easily blocked .Cheers anyway.
Edited by fastbob
Many thanks for all the replies so far , I'll look at them all and see what's on eBay.
try a zzr1100 d model tap
Thanks Tim , this looks promising, I'm guessing the two thin pipes on the left are from the tank , one being reserve, and the single fat one goes to the fuel pump. Should work on an ER5 but it would be perfect if the fat pipe pointed downwards.
or some of the zx range had one
Could be a winner Tim
