Octo1313 Posted December 8, 2018 Posted December 8, 2018 Hi all,Recieved my new 125cc zontes bike today. I'm a complete novice, only just done my CBT so I apologise in advance if my problem is just down to my own stupidity. It was working perfectly fine when it came, tested this morning by the garage and the delivery driver showed me it working before handing it over. Just went to sit on it and it will not start. You go to start it and it just revs, chokes and makes a fast ticking sound.I can only describe it as sounding like a car with no battery, however the bike is 1 day old?! Surely it's not a bike problem but something I'm doing wrong.Thank you in advance. Quote
Muttly Posted December 8, 2018 Posted December 8, 2018 Is the side stand down? My bike has a kill switch on the side stand? Failing that is there an engine cut out switch on the handle bars? I have both and have been caught out by both Quote
Bianco2564 Posted December 8, 2018 Posted December 8, 2018 Welcome to the forum.Have you got an owners manual?Read through that to see if you are operating it correctly. Quote
fastbob Posted December 8, 2018 Posted December 8, 2018 Here we go again , it's not your problem to solve . You have been sold a consumer product and it does not work . Ask the vendor to collect the faulty purchase and exchange it for one that is fit for purpose. Act quickly before you fall into the all too common trap of believing that it's YOUR bike and that YOU have a responsibility to fix it . A fridge, a lawnmower, a motorbike, a felt tip pen , your consumer rights are exactly the same. Welcome to the forum. Quote
mikestrivens Posted December 8, 2018 Posted December 8, 2018 Hello. As above it’s the dealership’s responsibility to ensure the bike is fit for purpose and show you how it works. Quote
Octo1313 Posted December 8, 2018 Author Posted December 8, 2018 Just tried it again and the bike died completely. Will be calling the company as soon as they open. Thanks all. Quote
Mississippi Bullfrog Posted December 8, 2018 Posted December 8, 2018 Sounds like either they didn’t fully charge the battery or something has drained it. The fast ticking is the solenoid bouncing in and out as the starter is engaged and the battery voltage collapses.Call the dealer and get them to collect it and check it out. Quote
BIKERDAD Posted December 8, 2018 Posted December 8, 2018 Also on mine if I don't hold the clutch in it won't start .. .. Quote
Via Posted December 8, 2018 Posted December 8, 2018 As mentioned give manual a quick skim first for starting procedure as some need clutch in all the time, others only if not in neutral. Some won't start with side stand down etc... If you're doing everything right then get on phone to dealer straight away. Quote
Octo1313 Posted December 8, 2018 Author Posted December 8, 2018 Everything seems to be right, clutch in and in neutral as manual states, kickstand up, petrol in etc. I should have mentioned I did start it fine at first, it's when I went away then came back and that's when it started choking.It got progressively worse, sounding like it was struggling, then to a dead car, then to just making the clicking sound. Now the display cuts off so I would think its a battery problem.As said above I'll go straight back to the supplier. I just wasn't sure at first if it was something stupid I had forgotten (like the kickstand for example). Thanks Quote
Via Posted December 8, 2018 Posted December 8, 2018 Is it carb or fuel injected? Auto or manual choke? If manual it can bog down and stall once warm with choke on at idle, likewise if off in this weather will probably struggle to start. Quote
Tango Posted December 8, 2018 Posted December 8, 2018 Everything seems to be right, clutch in and in neutral as manual states, kickstand up, petrol in etc. I should have mentioned I did start it fine at first, it's when I went away then came back and that's when it started choking.It got progressively worse, sounding like it was struggling, then to a dead car, then to just making the clicking sound. Now the display cuts off so I would think its a battery problem.As said above I'll go straight back to the supplier. I just wasn't sure at first if it was something stupid I had forgotten (like the kickstand for example). Thanks Sounds like the battery has run down......probably just needs a charge.....dealer may have had the bike sitting there for a while and not thought to charge the battery before delivering it...... Quote
Guest Posted December 9, 2018 Posted December 9, 2018 And what does a car with a dead battery sound like? ................Cue Simon & Garfunkel (a popular singing duo, for those under 55......) Quote
Bianco2564 Posted December 9, 2018 Posted December 9, 2018 And what does a car with a dead battery sound like? ................Cue Simon & Garfunkel (a popular singing duo, for those under 55......) Cecilia asked The Boxer if he was going to Scarborough fair.No he replied,,I've been to America to see Mrs Robinson and was homeward bound on the bridge over troubled waters when I was greeted with the Sound of silence from my new bike. Quote
Six30 Posted December 9, 2018 Posted December 9, 2018 And what does a car with a dead battery sound like? ................Cue Simon & Garfunkel (a popular singing duo, for those under 55......) Cecilia asked The Boxer if he was going to Scarborough fair.No he replied,,I've been to America to see Mrs Robinson and was homeward bound on the bridge over troubled waters when I was greeted with the Sound of silence from my new bike. They remind me of cartoon rabbits . Quote
Bianco2564 Posted December 9, 2018 Posted December 9, 2018 And what does a car with a dead battery sound like? ................Cue Simon & Garfunkel (a popular singing duo, for those under 55......) Cecilia asked The Boxer if he was going to Scarborough fair.No he replied,,I've been to America to see Mrs Robinson and was homeward bound on the bridge over troubled waters when I was greeted with the Sound of silence from my new bike. They remind me of cartoon rabbits .That was only Art Garfunkel. Quote
Guest Posted December 9, 2018 Posted December 9, 2018 And what does a car with a dead battery sound like? ................Cue Simon & Garfunkel (a popular singing duo, for those under 55......) Cecilia asked The Boxer if he was going to Scarborough fair.No he replied,,I've been to America to see Mrs Robinson and was homeward bound on the bridge over troubled waters when I was greeted with the Sound of silence from my new bike. Got there in the end............ And where's that wascally wabbit? Quote
geofferz Posted December 10, 2018 Posted December 10, 2018 And what does a car with a dead battery sound like? ................Cue Simon & Garfunkel (a popular singing duo, for those under 55......) Cecilia asked The Boxer if he was going to Scarborough fair.No he replied,,I've been to America to see Mrs Robinson and was homeward bound on the bridge over troubled waters when I was greeted with the Sound of silence from my new bike. Now I have 'cecilia' in my head - thanks. And you probably do now too - you're welcome. Quote
Stu Posted December 10, 2018 Posted December 10, 2018 come on guys this isn't helping the OP out is it!First thing you need to do is get a bike battery charger and charge the battery as you have flattened it trying to start it Quote
geofferz Posted December 10, 2018 Posted December 10, 2018 Can't he try a push start? I did it once - was very easy - 1st gear, clutch in, run forward with the bike, slowly let the clutch out, done. Quote
SometimesSansEngine Posted December 10, 2018 Posted December 10, 2018 Can't he try a push start? I did it once - was very easy - 1st gear, clutch in, run forward with the bike, slowly let the clutch out, done. Worthwhile jumping on just before you let the clutch out though? Quote
fastbob Posted December 11, 2018 Posted December 11, 2018 Can't he try a push start? I did it once - was very easy - 1st gear, clutch in, run forward with the bike, slowly let the clutch out, done. Worthwhile jumping on just before you let the clutch out though? Or quickly grabbing the clutch again before the bike sets off down the road without you . Personally I've always preferred second gear to bump start a bike and I would never run along beside it , that's just asking for trouble. Quote
Mississippi Bullfrog Posted December 11, 2018 Posted December 11, 2018 Can't he try a push start? I did it once - was very easy - 1st gear, clutch in, run forward with the bike, slowly let the clutch out, done. Worthwhile jumping on just before you let the clutch out though? Or quickly grabbing the clutch again before the bike sets off down the road without you . Personally I've always preferred second gear to bump start a bike and I would never run along beside it , that's just asking for trouble. I've always used 2nd for bump starting. It causes less mechanical strain and make it easier to start the engine. I suggested it was a battery issue early on. But the dealer ought to have made sure the battery was fully charged before delivery which it doesn't sound like it was - either that or there is a drain somewhere which needs fixing. Has the OP looked into that yet? Quote
