Zebralord Posted December 28, 2018 Posted December 28, 2018 I have a hyosung gt250 that is havjng some transmission issues and im unable to find a similar issue online. The bike pulls along and cannot shift below 3k on its own. I have adjusted the clutch and i know ita not that because i can move the lever out and it distinctly starts to grab properly an inch of travel in, if i increase the choke or give it throtte to around 3k rpm it shifts perfectly and doesn't pull, its a wet clutch, any help woulf be appreciated Quote
ThePhatomfart Posted December 28, 2018 Posted December 28, 2018 Seen you haven't had a reply, could you give a little more info, have you done anything to the bike ,service, chain adjustments,clutch , this shouldn't be a problem specific to your bike, so have a look for this type of fault among other Bikes Quote
mikestrivens Posted December 28, 2018 Posted December 28, 2018 Hello and welcome. Sorry can’t help with bike. Quote
fastbob Posted December 28, 2018 Posted December 28, 2018 I'd be happy to offer some advice if I could understand what you're getting at . Would I be correct to assume from your use of terms such as shift and transmission that you are an American gentleman ? Welcome to the forum. Quote
Snod Blatter Posted December 28, 2018 Posted December 28, 2018 All gears? Up and down?When was the oil last changed? Quote
