Headlamp retaining clip
JesterPilgrim
Was really hoping to find the actual part - I bought one of the Halfords H7 springs and have tried to bend it into shape - succeeded only in weakening the metal to the point of breaking with very little effort.
Get a piece of Piano Wire from a model aeroplane shop.
Wear protective eye gear when bending. I made undercarriage legs from it with a spring section made by wrapping round a former. But if it breaks it goes with a bang.
try heat applied but use pliers ...
the closest one I can find to match what you have is this one
https://www.ebay.co.uk/itm/Ford-Transit-Van-T280-SWB-Headlight-bulb-holder-retaining-spring-2000-2006-ONW/142476483729?hash=item212c429c91:g:5PwAAOSwC8FZbSUt
you could maybe try and make it fit with a bit of modification but its not cheap!
Or £40 for a headlamp unit.......https://www.ebay.co.uk/itm/KAWASAKI-ER6-F-ER6-N-FRONT-HEADLIGHT-HEAD-LAMP-2007/173541093300?hash=item2867daefb4:g:2UcAAOSwxSZboBrD&redirect=mobile...... 8-)
  • 1 month later...
this has caught my eye, i have a yamaha thundercat and the bulb retainer clip has snapped on it, meaning my bulbs a bit wobbly, its a H4 bulb, so will any H4 retaining clip from halfords fit it or are they different, the problem i have is i only have part of the clip which means i cant compare side by side to see if its the same.
Cheers folks
  • Sign up now
